Flywheel installed incorrectly
bdkennedy70
Send a private message to bdkennedy70
Trying to adjust the injector lifters on a d315 in a D4 7u. By looking at the valves, it appears the marks are wrong. When it shows 1&4 it should be 2&3, And when it shows 2&3 it should be 1&4. Would it be possible for someone to have installed the flywheel 180% out? If not, something is really strange. Any help would be greatly appreciated.
Mon, Nov 4, 2024 2:05 PM
Thank you received: 42
The subject of flywheel alinement has been discussed, so it is a possibility. I forget which models it was possible on. Hopefully bring this to the top brings you a better answer.
Mon, Nov 4, 2024 11:13 PM
side-seat
Thank you received: 15
Reply to Ray54:
Yes, The flywheel could have been put on at sometime incorrectly. There is no dowel etc to make it idiot proof to install.  The crankshaft flange and the flywheel have a mark at one of the holes to align the proper bolt hole up. You can't see them unless the flywheel is removed. I guess your best bet is check the valve timing with a dial indicator. That is described in the D315 Serviceman's Reference Book. And see which timing marks align with your flywheel at #1 piston.
Tue, Nov 5, 2024 1:48 AM
