Flywheel clutch slipping
valerie-verboncouergreen-7560
Send a private message to valerie-verboncouergreen-7560
I have a 1954 caterpillar d2 I was using it for dozing and clutch stopped snapping over center and clutch seemed slack. Any ideas on what the issue could be?
Wed, Nov 11, 2026 11:14 PM
Thank you received: 62
It needs to be adjusted. Since it looks like you're a member if you don't have an Operators Handbook use the online library on the site here to find the book and read how to do it. Then if you want more explanation come back with questions.
Wed, Nov 11, 2026 11:21 PM
d4angelo
Thank you received: 8
It is easy to adjust. Remove the cover that has the oil tube and look inside. You will see a spring loaded button. Pull the button out and move the button/pin to the next hole. I would try one notch at a time.
Fri, Nov 13, 2026 1:27 AM
I completed the adjustment. The plunger was free, but the spider would not rotate clockwise. I noticed in the bottom of the bellhousing there were three broken links to the clutch. They had sheared around the cotter pin hole. Can these links be replaced through the inspection cover, or will the clutch need to be pulled? Are these links available?
Sun, Nov 15, 2026 7:35 PM
Thank you received: 78
I bought some from Hector Gemme in Quebec for my buddy's 5U so he's worth trying - send a message to gemdozer. That said, I'd say the pins might be a standard side you could get from McMaster and the links are very simple so if you have a machinist handy, he could whip out some new ones for you easily. You could even make them yourself if you're accurate with teh drilling. It's just two holes on a flat piece of steel. Use one of the intact ones as a pattern
Sun, Nov 15, 2026 10:34 PM
