Flywheel clutch brake?
Showing 1 to 7 of 7 results
RayMiller4288
Send a private message to RayMiller4288
I have a question about the clutch brake on a d2 5u? I have the clutch out and I was wondering if it a metal brake pad or if it something else
Sun, Mar 1, 2020 11:17 PM
Its a fiber composite brake band material, available from Cat part#6Y7178 $45.66, each qty two required.
Sun, Mar 1, 2020 11:39 PM
Has anyone ever looked at snapping a clutch brake disk from a heavy truck transmission around the clutch shaft on these tractors. I am familiar with those on old Mack trucks and they are made to open up and slip in place around the shaft before snapping back together to make them a circle again
I think they are cheap and if one can be found to fit, should not require clutch removal
Mon, Mar 2, 2020 12:00 AM
You dont have to remove the clutch, just unbolt the coupling, 3H4121, the clutch disc are on the coupling. Unless tractors before 5U13237 dont have a coupling? Never had an early one opened up.
Mon, Mar 2, 2020 12:08 AM
RayMiller4288
The d2 5u is a early one that it says that it bolt to the back of the case
Mon, Mar 2, 2020 2:34 AM
Thank you received: 50
Reply to RayMiller4288:
They don't really say what the material is, just a clutch brake facing that is riveted to a plate bolted to the case. Could be brake material or bronze impregnated brake type lining material, most likely with asbestos of the era.
Brake assy 4B3435
Disc 4B3436
Rivets (6) 7B5044
Mon, Mar 2, 2020 2:56 AM
RayMiller4288
Brake assy 4B3435
Disc 4B3436
Rivets (6) 7B5044
Thank you old magneto I'll have to look up those numbers in my part book
Mon, Mar 2, 2020 3:44 AM
Disc 3B3436 changes to 6Y7179 $84.81 from Cat
Disc assembly 3B3435 changes to 8E7629 $137.17 from Cat
Rivets ?
Mon, Mar 2, 2020 4:09 AM
