Flushing engine coolant jacket ?!
Showing 1 to 7 of 7 results
Xtremist
Send a private message to Xtremist
Hey Guys,
I recently pulled the radiator out of my D6C because the machine runs right on the cusp of overheating and when you look in the rad cap is really scaled up and rusty.  At some point before i owned it the transmission cooler started pushing oil into the coolant causing a bunch of sludge etc.  As usual it was run like that a lot longer then it should have been.  Im going to hopefully get the rad cleaned out by a local rad shop but i was also wondering if i should make some fittings and hook up a garden hose or my hot water pressure washer to the block to try and get some of the sludge that im sure is probably built up around the cylinders....  Has anyone ever done anything like this ?
Thanks for the help
Mon, Oct 17, 2022 6:21 AM
kittyman1
hate to be the Debbie Downer here...but maybe got the sequence mixed up... this might be the hard way....and yes anything is possible..
-i would have tried some radiator, coolant system cleaners before hand...mostly caustic solutions i think, then flush etc...
Wed, Oct 19, 2022 11:23 AM
Thank you received: 77
Reply to kittyman1:
Folks have done that. Be aware of the possibility of forming new leaks because sometimes that crud is hiding latent weak spots in o-rings, plugs, etc.
Wed, Oct 19, 2022 8:35 PM
Thank you received: 62
My experience has been the taking the radiator apart and rodding it out does much more good than a chemical flush. If the cooling system has had oil in from your comment about oil cooler leaking, flushing with something like Tide cloths washing soap has been reported to work well. But that might do more good circulating with the engine running and warm than trying pump it through the block at this time. But if you suspect muddy water has been put in the cool system that might come out better now with a great volume of water..
Wed, Oct 19, 2022 10:27 PM
Thank you received: 54
Reply to Ray54:
use laundry detergent its not as harsh as the proper flush products. just use double the rate for top loader washing machine.
yes they are caustic based and so is laundry detergent.
lanotec also make a citrus oil based cleaner called citra-force it works very well and is ph neutral. not sure if you can get it overseas but there are several similar products on the market.
Thu, Oct 20, 2022 3:51 PM
Xtremist
Reply to trainzkid88:
Thank you for the feedback, I actually did the good ol laundry detergent trick and then went and worked it hard for a few hours. it helped a bit but didnt really do enough.... s an update from the first post, i took it into the RAD shop, they said that the coler is on its way out. the top part of the core is sweating and could let go at any moment. so does anyone have opinions or options on a new RAD core cause WOW are they ever expensive. The RAD shop quoted $3700 to repair it, the local aftermarket Cat supplier (union tractor) quoted $2500 for just the core if i do the work myself. Seems crazy high to me. If i could source the parts i could probably build my own core as im a competent tig welder and fabricator but i have no idea where to search for parts. Thank you to anyone who can lend their thoughts on this !
Thu, Oct 27, 2022 9:15 AM
Reply to Xtremist:
its a lot of work to make a rad. but what you could do is get a modern aluminium rad from say pwr or aussie dessert coolers and fit the old sides and tanks around it so it looked the part. these australian companies both do custom stuff for all sorts of applications. ally rads are much more efficient you look at what a current model v8 has compared to what they used in the 60s its half the thickness.
by the way you dont need the oil cooler actually but what we did was get a trans cooller for a landcruiser and mounted that in front of the rad and it works
depending on how rotten it is you may be able to flow solder over the bad spots and put off the replacement. the best is a replacement core or a modded modern unit.
Thu, Oct 27, 2022 1:49 PM
mog5858
if you have the cat part number for the rad / core part type it in on eBay and or machinery trader has a great parts look up. at lest your see if there's lost out there and what the going rate is right now.
Sat, Oct 29, 2022 8:40 PM
