Final drive leak D4D 49J
Showing 1 to 10 of 10 results
moooz
Send a private message to moooz
been trying to fix an oil leak in the RH finals.
Have installed new duo cone seals in board of the sprocket as well as out board. Put new oil in and still leaking oil from between sprocket and final drive case.
Reading the dis-assembly & assembly instructions there is mention of a special tool Seal Installer IS8966. Possibly the duo cone seals have not seated correctly. The tool looks in the pictures like a rim of sorts that is used to seat the seal. Noticed the o ring wants to roll off the retaining rim.
I would be interested in suggestions what's used to substitute the special tooling and any other information of relevance to the leak.
thanks
Leo
Where every day's a Sunday
Mon, Jan 12, 2015 12:30 PM
DPete
Had a final leak on a D8H years back, turned out to be O-rings on the aluminum part that the duo cone rubber ring seats against, always replaced them after that when we had a final apart.
1962 D4C
Mon, Jan 12, 2015 7:36 PM
rjh-md
Reply to DPete:
Make sure the surfaces that the rubber ring on the Duo cone seal rides is free of dirt ,wire brush or sand surfaces on final drive case side and sprocket side .Check surface for a crack in final drive case . If you have the alumiun cages that was mentioned earler check for a crack in the cage ,and slways install new O rings behind the cage .
The tool shown only compresses the rubber ring to install it in the groove .same thing can be done by evenly working the rubber ring in the groove with your fingers .A little liquid soap on the rubber O ring makes it easer to seat the O ring in the groove so that It doesn't twist
Mon, Jan 12, 2015 9:55 PM
Skinner
Thank you received: 38
Reply to rjh-md:
The sprocket can be warn where the duo cone seal fits in, causing the seal to come out slightly and leak or even pinch the duo cone seal when assembled . I've been fighting this on my d8K 76V for about two months now. If you have the correct tooling it can still leak in this case.
Mon, Jan 12, 2015 10:11 PM
Thank you received: 63
Reply to Skinner:
Check distance between sprocket face and spline shoulder.
Dimension "A" should be 0.06 to 0.18 in.
Tue, Jan 13, 2015 12:55 AM
tctractors
rjh-md, has posted up some sound advice mooz, you dont need any fancy installer on the duo-cone seals, what tonnage are you pressing the rim on to and are you adjusting things up correctly, plus as O.M. has already posted the installing depth is important, D8H/K hubs do not have the alloy seal ring seatfitted, but often the lip gets worn out that retains the seal in place on build up, this can easily be sorted with a hammer in no time.
tctractors
Tue, Jan 13, 2015 1:55 AM
moooz
Reply to tctractors:
tctractors
thanks all for the help.
tctractors, we pressed about 25metric tonnes and followed manual as best.
Bugger, but will disassemble and try again.
Leo
Wed, Jan 14, 2015 4:48 PM
moooz
Reply to moooz:
while installing the the bearing cup into the cage assembly p/n 9k6842
described in 6k4665 Final Drive Group, managed to damage the aluminum rim seal insert that the outer duo cone seal set abuts on-best description is that is about 5/8" wide, angle rim that inserts into the end of the cage assembly.
Now the local cat dealer Hastings Deering suggests the p/n is a Retainer p/n 4k212? Available ex USA for $142 + post $12, non refundable if wrong.
Leo
Wed, Jan 21, 2015 6:38 AM
moooz
Reply to moooz:
Got an aftermarket P/n 4k212, turns out to be the aluminum cages for the inner duo cone seal set.
Also, Cat dealer sent me a set of d/c seals that I returned. So having no luck at all.
Leo
Fri, Jan 30, 2015 9:14 AM
Reply to moooz:
I looked up the seals in the 82J (equivalent to the 49J) for the same 6K4665 final drive group and the seal group is a 4K6049 (4 required per side). Does not show a part number for just the seat ring.
Regal shows the 4K6049 as a good number at $23.88 ea. so other after market sources ought to have them as well.
Fri, Jan 30, 2015 10:35 AM
moooz
thank you Old Magnet, I'll make further enquiry's with your info.
Leo
Sat, Jan 31, 2015 3:54 AM
