Final drive, cat 955l leak, procedure .
Showing 1 to 10 of 11 results
uisum
Send a private message to uisum
hello people, the final drive of the cat 955l leak.
I inserted two liters of oil and after an hour of use I checked and oil had disappeared.
You have the complete gasket replacement procedure. Thank you
Wed, Jul 17, 2019 11:28 AM
Unless you get lucky and tightening the outer final drive bearings takes care of the leaking your in for a change of final drive seals. A fairly major job requiring hydraulic puller and press equipment.
Wed, Jul 17, 2019 10:54 PM
uisum
ok.
I checked the level from the back hole and about halfway through.
We need about 2 liters to fill it.
He loses them all.
I assume the loss is in the upper part.
Thu, Jul 18, 2019 2:25 AM
Reply to uisum:
ok.
He loses them all.
Are you seeing leakage on the tracks below the final drive hubs?
Oil has to go somewhere. If not leaking external than it is most likely adding to the steering clutch compartment.
Thu, Jul 18, 2019 2:33 AM
uisum
Yes gets lost outside ..
you can see the oil marks from the top over the track.
I think I'll leave it all like this.
Could it be a problem?
Thu, Jul 18, 2019 2:50 AM
bursitis
Reply to uisum:
take the bottom plug out and rinse the case with some diesel or solvent. see how many chunks come out and let us know.
Thu, Jul 18, 2019 5:17 AM
Reply to bursitis:
Is the top of the final drive case worn through from the track wearing on it??
Thu, Jul 18, 2019 7:49 AM
uisum
Hi, what do you mean?
I use the translator (sorry).
Thu, Jul 18, 2019 10:51 AM
uisum
Reply to bursitis:
hi ,What could have happened?
Thu, Jul 18, 2019 10:54 AM
Glum
Reply to uisum:
Quite a few things could be the cause of the leak.
A loose outer hub on the sprocket shaft can pop the outer nut off the threads.
Wire could have damaged the seals.
Might just be worn bearings needing adjustment.
Bearings may have collapsed.
Loose sprocket on the splined hub.
First check the the bearing pre load and outer nut.
If that doesnt work, you will have to start stripping.
You need special equipment when it comes to pulling off and pushing on the sprocket.
Thu, Jul 18, 2019 11:34 AM
uisum
Reply to Glum:
[attachment=54728]IMG_20190718_073538.jpg[/attachment][attachment=54729]IMG_20190718_073523.jpg[/attachment]
I'm not an expert, but the bolt doesn't seem to have come in until the end. Am I wrong, or is this normal?
thank you
Thu, Jul 18, 2019 12:44 PM
