final drive and trans oil?
lj98
Send a private message to lj98
i know this is probably been asked a lot but i cant find on search.i have a late model d47u sn 41122 and i want to change all fluids. Do the finals and trans share the same oil on these machines and do you recommend 30 wt or gear oil.
Thu, Nov 29, 2012 9:57 PM
lj98
Forgot to mention tractor also has a winch .I cant find out how to fill or check final oil. Please help .
Fri, Nov 30, 2012 1:19 AM
Thank you received: 46
Reply to lj98:
The transmission and bevel gear share the same oil but not the finals.Cat went for a time saying to us a lite oil but has gone back to saying gear oil.I have always used gear oil.
Ray
Fri, Nov 30, 2012 1:32 AM
gemdozer
Reply to Ray54:
Ray
The transmission and final drive use the same oil 80/90 gear oil and you have a plug each final drive for refill
Fri, Nov 30, 2012 2:02 AM
ol Grump
Reply to gemdozer:
Regrading the winch, you didn't state if it was a D4 or D4N. In either case, there are drain plugs at the lowest point on the cases on both sides. A ways above the plug on the left side, there is an oil level plug and towards the top there is a fill plug. According to the instructions, 90 wt oil is to be used. I use 80w-90 in all compartments; tranny, finals and winch.
Fri, Nov 30, 2012 8:16 PM
lj98
Reply to ol Grump:
Thanks for the info,I couldn't figure out how to fill finals with the winch.I finally found that the winch has holes all the way through to check and fill finals.The winch is a D4D
Fri, Nov 30, 2012 9:12 PM
