Final Drive adjustment wrench
Dizzel
Send a private message to Dizzel
Hi All
I’m wondering if anyone has info on the adjusting tool used to tighten the final drive lock ring. My D6b is leaking oil on my right final and I want to make sure things are correctly tightened. Weather or not this fixes the leak I don’t know but I don’t want to damage final gear teeth by not having it correctly set.
Is this a Cat only tool or is it possible to make one?
Wed, Aug 21, 2019 5:31 PM
hfdzl
OTC makes a big adjustable hook spanner, I recently bought one off eBay for $100. I don't know if that will stop the leak. It could be final drive bellows seals.
Wed, Aug 21, 2019 7:29 PM
BillWalter
Reply to hfdzl:
I have one. I would sell for $75.00 plus cost of shipping from Kansas City,Mo by UPS
However, you can tighten FD bearings with a good strong pry bar. make sure the clamp bolt is loose and the lock removed.
!!! Standing out from Final Drive, looking towards the FD, turn the adjusting nut counter clockwise, that will force the bearing and holder in to force outer and inner bearings together to make a tight bearing fit.
Thu, Aug 22, 2019 11:11 PM
bcwayne
Reply to BillWalter:
[quote="BillWalter"]I have one. I would sell for $75.00 plus cost of shipping from Kansas City,Mo by UPS
[email protected][/quote]
Private message sent.
Fri, Aug 23, 2019 8:17 AM
| Kingaroy, Queensland
