Fifteen Head Bolt Specs
Plorenz23
Send a private message to Plorenz23
I have been looking for head bolt specs. I have read that you should start in the middle and work your way out. Also tighten the bolts in about three rounds. Just wondering what to torque the bolts to. Thanks in advance for any help.
Cat Fifteen (PV 714)
Sat, Aug 25, 2012 9:25 AM
Thank you received: 35
as the vertical pony engines are basically 2 cylinders of the above units I have the scanned specs below for the 7/16" stud/nut size at 55 lbs/ft.
A Spec sheet for later ponies with 1/2" stud/nut size lists the torque at 67lb/ft.
Yes, if the torquing pattern is not given then spiral out from the center in 3 steps is a good safe pattern to use.
The other scans below are from a Torque Wrench hand book and give good pointers for achieving correct even torque.
Hope this helps.
Sun, Aug 26, 2012 12:09 PM
MARCOTEN
Reply to edb:
Hope this helps.
just had the headgasket renewed on my 15,
what edb wrote is perfect (and on the pictures there is written: nuts must go on easy with hand), thats what i didto arrage that : all nuts i screwed on to all studs with the air gun a few times on and off, and lubed it with wd40 to arrange that the run easy.
and at Olsons gaskets they said to torque a first sequence when installed, a 2nd torque sequence after engine has run a while so when hot and cooled again , and then a 3rd sequence after a couple of hours running and cooled down,
They hould not torque on third try very much. If it does-check your studs/nuts.
i did the 1/2" studs / nuts on 81 pound/feet , but a few nuts i had to trow away they were to worn and were not getting to the right torque they turned loose.
75 p/f could be used aswell, start with a 55 round then 65 and at last 75 p/f .
Hope this helps
Sun, Aug 26, 2012 1:44 PM
Plorenz23
Reply to MARCOTEN:
Hope this helps
Thank this is exactly what I needed.
Mon, Aug 27, 2012 11:20 AM
Plorenz23
Reply to MARCOTEN:
Hope this helps
Thanks- This is exactly what I was looking for.
Mon, Aug 27, 2012 11:21 AM
