Fifteen cylinder numbering
Wig
Send a private message to Wig
Can someone tell me the numbering of the cylinders on a model Fifteen? Before I get any dumb answers, I’m guessing it is typical 1,2,3,4? Is it numbered from front or from the back? Thanks
Fri, Dec 13, 2019 5:04 AM
STEPHEN
1234 numbered from the front
Fri, Dec 13, 2019 5:56 AM
Thank you received: 93
Hi Wig,
there are no dumb questions, except for the one that is not asked and a goof up results.
The Engine Cylinders on a Fifteen will be numbered from the front of the engine.
Firing order is 1-3-4-2.
Valve Lash 0.008" all valves-cold.
Hope this helps.
Fri, Dec 13, 2019 6:06 AM
josh
Thank you received: 14
Reply to edb:
Hi Wig,
Hope this helps.
Per the instruction manual, 1-3-4-2.
Fri, Dec 13, 2019 2:23 PM
Reply to josh:
Is there any way to check the intake manifold for leaks while it is on the machine? My exhaust heat transfer jacket is rusted and exploded.
[attachment=56302]10859804_0.jpg[/attachment]
Fri, Dec 13, 2019 9:19 PM
