Fifteen BEV 10 rebuild
Showing 1 to 10 of 15 results
dadawg
Send a private message to dadawg
I am in need of a rebuild kit for my bev 10 carb. Where can a guy get the kit and any info on the carb. This one I have was in pieces when I got my hands on it. I have a pretty good idea on where they all go. But it would be nice to have a schematic if there is something out there. Also when I got this Cat it came with a Fairbanks Morse model J mag. in searching this forum I see that is not the proper mag. Any input on the pros and cons of using this mag would be great.
Mon, Jan 4, 2010 11:22 PM
B4D2
Don Campbell in Canada has the info you need. Check the magazine for his ad.
Mon, Jan 4, 2010 11:42 PM
Reply to B4D2:
I'm a little out of my turf on these old gas cats but the info I have shows the 10 & 15 using the Eisemann GV-4 magneto. Also an option to use the American Bosch MJB 4A 102 with coupling IC 408 V12 on the 10, 15, & 20.
I have often heard the Fairbanks Morse unit as being a preferred unit for its rugged construction and reliability.
Some body help if I'm not on target😊 😊
Tue, Jan 5, 2010 12:43 AM
John from Fresno
O.M.
Do you have a picture of what the GV-4 looks like?
Thanks,
John
Tue, Jan 5, 2010 1:08 AM
dadawg
Reply to B4D2:
I am a new member and have not recieved a magazine yet.
Tue, Jan 5, 2010 1:47 AM
Reply to dadawg:
I don't see a Don Campbell but there is a Bill Campbell at 813-677-2498 or email
[email protected] in Ontario Ca. specializing in Ensign carbs.
John,
I have cross section and parts break down but no identification picture of actual unit.
Tue, Jan 5, 2010 2:42 AM
bruce oz
Thank you received: 23
John,
hello ,this the best i can do ,only a drawing ,bruce oz
gv-4 magneto
http://www.oldengine.org/members/diesel/Magnetos/Mag80.htm
Tue, Jan 5, 2010 3:13 AM
Reply to bruce oz:
gv-4 magneto
OK,
Found a GV-4 picture after rooting around in the website that bruce oz posted.
http://www.oldengine.org/members/diesel/Eisemann/Mag73.htm
More info at:
http://www.oldengine.org/members/diesel/Eisemann/MagData.htm
Tue, Jan 5, 2010 4:49 AM
John from Fresno
OK,
More info at:
O.M.,
Is this one?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110472320039&viewitem=&sspagename=STRK%3AMEWNX%3AIT
I noticed that this one didn't have the retard lever as the one in your picture. Does the PV15 have a rod to retard the timing? Or is that an option on the GV-4 magnetos?
John
Tue, Jan 5, 2010 8:44 AM
Reply to John from Fresno:
O.M.,
Is this one?
John
Hi John,
My info shows the 10 & 15 as using the same GV-4 magneto. Both the drawing and the picture clearly shows the timing arm.
Not being all that familiar with the 10 & 15 that's all I can tell you.
Hopefully some one else can verify.
Tue, Jan 5, 2010 9:04 AM
B4D2
John,
[quote="Old Magnet"]I don't see a Don Campbell but there is a Bill Campbell at 813-677-2498 or email
John,
I have cross section and parts break down but no identification picture of actual unit.[/quote]
Thanks OM, must have had brain freeze. It has been cold these parts. I just got home to review my magazine and saw your correction. Yep, that's the guy. Also, for help with the mag, try these guys http://standardmagneto.com/
Tue, Jan 5, 2010 9:40 AM
