Extra solenoid
Extra solenoid
Showing 1 to 10 of 12 results
ShawnP
Send a private message to ShawnP
Can anyone provide me some insight on how to wire a 955C starter. I have the manual but with this new starter I have an external solenoid as well as Solenoid on the starter. [attachment=30255]image.jpg[/attachment]
This is the crude wiring diagram the guy at the shop gave me.
Sun, Jul 26, 2015 3:50 AM
that diagram seems to show a pusbutton that activates a solenoid that will send power and activate the starter solenoid---however it shows a disconnect on the + wire instead of on the - wire that most Cats have
Sun, Jul 26, 2015 4:09 AM
Reply to dpendzic:
Cat normally does not use a solenoid to activate the main solenoid.
If this is a direct mount solenoid on a 40 or 42MT starter it isn't going to fit on the loader without modifying the starter lever housing.
I already gave you the wiring diagram for a direct mount solenoid starter.
Need to see a picture of this new starter showing the solenoid and looking at the drive end housing.
Sun, Jul 26, 2015 4:27 AM
cojhl2
Reply to dpendzic:
Dependzic you are correct, disconnects should be on the ground side because there may be other draws that do not path through the main cable. An example is the fusible link on some vehicles. If the disconnect is on the ground side it includes all circuits.
Sun, Jul 26, 2015 4:53 AM
AJ.
Send a private message to AJ.
Reply to cojhl2:
I converted a lot of Cats to direct start nearly sixty years ago and we did not use a solenoid [relay] on the exciting wire for the starter,there was a solenoid used for the glow plugs,put the cables and the wires back to where they were on the old starter,leave the solenoid he gave you off,did you get the old starter repaired or is this a replacement if so check that is the dog is the same,is the machine fitted with glow plugs,the standard fitting for the disconnect switch is usually on the ground cable,but that is not an issue one or the other and it is probably on right.
Good luck
AJ
Sun, Jul 26, 2015 5:36 AM
ShawnP
Reply to AJ.:
Good luck
AJ
The new starter has a solenoid mounted on the top and this machine is fitted with glow plugs. The dark picture is a picture of the back of the new solenoid and the other picture is the old one. The guy at the shop who sold me the new starter seem to think that I should hook up both
Sun, Jul 26, 2015 5:49 AM
Reply to ShawnP:
I think it would depend on the amp draw of the solenoid on the starter and if the pushbutton is rated for that amp load--otherwise the secondary solenoid would have to handle that amp draw.
Sun, Jul 26, 2015 8:53 AM
ShawnP
Reply to dpendzic:
When I first bought this cat, they had both the positive and negative wires running into a disconnect. Before I put this new starter in, that set up worked just fine. Is there any reason that I would need to run both solenoids to crank over this new starter? Or could I just wire the starter as my old one was and hook it up to my own Old solenoid?
Sun, Jul 26, 2015 9:15 PM
KenP
Send a private message to KenP
Reply to ShawnP:
Shawn you have received a complete replacement Delco 42MT Starter to replace your older Delco Inershia Drive Style Starter. Completely remove your original Soleniod Switch that is in pic #1. Did the Rebuilder supply you with the new 24 Volt Magnetic Relay Switch. If not I recommend to purchase a Cole Herse Part #24063 Soleniod/Relay Switch & mounted where or as close to the old Starter Soleniod that is disguarded. Use the machines exsisting trigger wire from instrument panel Start Switch to activate the new Cole Herse 24063 Soleniod Relay Switch. This new relay acts like a Clutch Slave Cylinder to the Starter Soleniod Switch to take the load of the amperage draw of the Starter Soleniod which on this 24 Volt 42 MT Starter Soleniod Switch is about 30 to 35 Amps. The Cole Herse Starter Soleniod Relay Switch only requires about 2 Amps. You now will need to make up new Battery Cables as you know are eliminating the old style Starter Soleniod Switch. I would suggest running 10 gauge wire from new Cole Herse Starter Soleniod Relay Switch to 42 MT Starter Soleniod Switch. As I stated in prevoice post get your Battery Cables maded up with good Thomas & Betts or Quick Cable Battery Cable Terminals that are either properly crimped or soldiered. If you need further assistance give me a call at tel. 860-528-8174. Good Luck Ken Plourde
Sun, Jul 26, 2015 9:39 PM
AJ.
Reply to KenP:
Well a picture is worth a thousand words,when I seen the picture of the old solenoid I realize you had the old style inertia starter and you are replacing it with a pre engaged one,the last time I seen an inertia starter on a Cat was back in the fifties on a grader,we never used them on any of the conversions we done as they not that long lived and the pre engaged was available from a home source.the little sketch I posted before is the way to hook it up.
Good luck
AJ
Tue, Jul 28, 2015 4:31 PM
ShawnP
Reply to AJ.:
Good luck
AJ
After fighting with the removal of the old starter and the installation of the Delco Remy 42MT starter, the 955C starts within 5 seconds. Complete night and day difference. I believe the bad starter was also the source of my batteries being drain so fast after a hard start. After seeing how a new starter compared to the old, I now realize that my old starter must have been going out long before I purchased the 955C. The new starter has a starter solenoid mounted on it, I integrated a Cole Herse 24063 Soleniod Relay Switch. This worked out well. I had a buddy of mine come out and do the wiring (much cleaner job than previous wiring job). The hardest part of this whole endeavor was removing the old starter because of the fact that I had to remove both the front and back belly pans and move the return hydraulic pipe that was directly underneath the starter. Once the starter was installed the wiring process went surprisingly fast.
Wed, Aug 19, 2015 12:41 AM
