Expressions of interest in Reproduced 2 Ton Parts .
Showing 1 to 7 of 7 results
ianoz
I have been asked to see what interest there is out there in back to spec parts for Holt and Cat 2 ton machines .
Inlet and Exhaust manifolds for early and late model machines
Top and Bottom Rollers .
Cam gear .
My email address here is no longer current So no emails please .Start doing long hours as of tomorrow , so no PMs .
Replies on the thread only .
Wed, Sep 12, 2018 5:14 PM
u-joint
Send a private message to u-joint
complete air cleaner assembly.
Sun, Sep 16, 2018 12:27 PM
ianoz
Reply to u-joint:
At present ,Air cleaners are not on the list to make .
Maybe try Chad and see what he has in used parts .
Sun, Sep 16, 2018 7:18 PM
WILLSY/AUS
Send a private message to WILLSY/AUS
Reply to ianoz:
Hi Ian,
A crankshaft timing gear I require.
Cheers, Willsy/Aus.
Wed, Sep 19, 2018 5:36 AM
rax200
Reply to WILLSY/AUS:
Hi Ian,
Cheers, Willsy/Aus.
Hi ianoz,
I am looking at getting some gears made for the generators next time i go overseas i could also look at other gears as well.
Regards
Wed, Sep 19, 2018 3:35 PM
ianoz
Reply to u-joint:
Hi U Joint . I have been told Air Cleaners are on the list of parts to be made , but i can't give you a timeline for this part .
Thu, Oct 4, 2018 7:34 PM
steeltracs
Thank you received: 10
Reply to ianoz:
Many years back Bill Santos had someone in the Placerville area spin new air cleaner canisters
Thu, Oct 4, 2018 11:49 PM
Mike Meyer
Thank you received: 6
Reply to steeltracs:
I had new aircleaner parts made for the 2 Ton a few years back including the spun sections, it was a big job finding a metal spinner and creating the patterns, plus I had to wreck a good aircleaner in the process so it wasn't cheap, and at the time I made enough spares to put together 10 complete aircleaners which I envisage will be sold through Chapter 19 here in Australia.
Mike
Fri, Oct 5, 2018 3:41 AM
