Reply to Sasquatch:
This thread reminds me of the first time I got my 5U D2 running back before I restored it. After doing all the necessary prechecks and getting the pony running, then cranking the diesel to bleed the fuel system, I opened the throttle and the diesel rumbled to life. Just as I started to feel that sense of accomplishment I noticed out of the corner of my eye that something was dancing across the top of the radiator. Turns out it was the stamped tin top portion of the radiator cap which I had earlier found had come loose from the bottom portion that engaged the radiator neck. Since I still had the hood off of the machine, it danced its way to the very edge of the radiator and fell straight into the spinning fan before I even had a chance to do anything about it. It hit one of the fan blades and caused it to bend, sending it straight into the radiator. The blade sliced through about a dozen of the little cores before coming to a stop and causing the belt to slip. I shut the engine down as fast as I could but by then water was running all over the place. The worst part is that I had made a mental note earlier in the day to remove that loose cap piece before trying to start the machine, but in my haste I had neglected to follow through. I still have that tin cap piece on a shelf in the shop, and even after it had destroyed that fan blade it still doesn't look to have a single mark on it. :censored:
And you know Toby, I bet that all happened in slow motion and you could see where it was headed but... Man, that happens to me every day : )
Still, on the $ side, I've calibrated myself such that to me, a hobby is not supposed to be a money-maker (if it is, great - but shouldn't be expected) - if it is expected to make money, then it's called a "job" : ) Based on that, I'm free to spend as much as I like on it within the confines of what the boss will let me get away with of course....
