exhaust pipe for pony motor on d6 9u
Tydavis
Send a private message to Tydavis
Did they have two different types of exhaust pipe that comes up out of the hood for pony motor on the 9u? The one I have comes straight up and the cross brace on the hard nose hits it. Did they make one that comes up and has a curve to it and then goes straight up to go around the cross piece?
Tue, Jan 10, 2017 10:00 AM
rmyram
check your hardnose mounts and your engine mounts. is something moving that should'nt be? there isn't alot of clearance for the exhaust pipe of the pony but there should be enough. to prevent touching.
Tue, Jan 10, 2017 10:05 PM
Dozer Doug
Send a private message to Dozer Doug
Reply to rmyram:
The pony exhaust on my 9U has a curve and comes up right in front of the cross member without hitting it. Maybe you can fabricate one. I Have searched quite a bit and cannot find any pony exhaust pipes or manifolds for the D318 pony.
Thu, Jan 12, 2017 6:15 AM
Thank you received: 52
Reply to Dozer Doug:
Make sure the cross brace is installed correctly with the the long side of the mounting flanges facing forward.
Thu, Jan 12, 2017 6:51 AM
Tydavis
The pony exhaust on mine came straight up and didn't have the curve in it. I don't know if it's because it came off a power unit is why it was straight and didn't have a curve in it. I fabricated it to have the curves and works just fine now! Thanks for the information
Fri, Jan 13, 2017 11:30 PM
