Excavator trouble
Excavator trouble
Showing 1 to 10 of 18 results
tacacat
Send a private message to tacacat
Just bought a 235C 1988 #5AF00108, seems the left final drive works as should , but the right side is 1/2 speed of left , it has power to it but not as fast as left side track ? should I be looking at final drive or steering valve assembly ?
Thanks in Advance Tim
Wed, Nov 12, 2014 6:19 AM
catsilver
First bit of advice on the Cat excavator is don't take anything apart until you have done the proper checks, the tracks are driven by separate pumps, so their performance, or lack of it will, also show up in the speed of other operations. the steering valve only operates the pilot circuit, there are two separate spool valves which select track drive, controlled by the pilot system. The possible causes are:- one pump down on performance, one track motor has excessive port plate leakage, the track spool valves sticking and the most likely is leaking past the seals in the rotary valve in the centre of the machine. Get hold of the book, check the speed of all circuits first, then start working out most likely causes.
Wed, Nov 12, 2014 8:07 PM
bob
Send a private message to bob
Reply to catsilver:
As you travel forward or reverse cycle on and off of the travel peddel a few times. See if you notice and popping and banging in the slow side drive lines. Also what happens as you try to correct the travel with the steering lever. Is forward and reverse travel the same?
Later Bob
Thu, Nov 13, 2014 8:44 AM
tacacat
Reply to bob:
Later Bob
[quote="bob"]As you travel forward or reverse cycle on and off of the travel peddel a few times. See if you notice and popping and banging in the slow side drive lines. Also what happens as you try to correct the travel with the steering lever. Is forward and reverse travel the same?
Later Bob[/quote]
Bob-
When you compensate with the steering control and slow down the fast track all is fine , no strange popping or banging from below when cycled thur turning , forward & back , and yes same in forward as well as reverse , its very consistent , seems to have all the turning power that right track has ( but hard to tell ) ?
Thu, Nov 13, 2014 9:32 AM
tacacat
Reply to catsilver:
Can I tap a set of pressure guages in line at these points ?
Thu, Nov 13, 2014 9:49 AM
catsilver
Reply to tacacat:
The first pressure to check is pilot to the track spool valves, put four in to the plugs on the ends of the main track spool valves and look for equal pressure on all four at various speeds straight ahead and reverse, if all is equal forget the steering valve, if uneven, the steering/ travel valves (under the cab floor) could be sticking or have a seal blown.
Thu, Nov 13, 2014 7:59 PM
bob
Reply to tacacat:
Later Bob[/quote]
Bob-
[quote="tacacat"]Bob-
When you compensate with the steering control and slow down the fast track all is fine , no strange popping or banging from below when cycled thur turning , forward & back , and yes same in forward as well as reverse , its very consistent , seems to have all the turning power that right track has ( but hard to tell ) ?[/quote]
I suspect the pump volume is low on that circuit. You need some one to help, remove and plug the signal line to the pumps(small line to bottom rear) then have some one try to drive while you look at what comes out of the signal ports on the pump. Servo leakage can shut down pump volume. Then try driving with lines off and see how it drives. Power will be low drive straight only.
Later Bob
Thu, Nov 13, 2014 9:13 PM
BobPV15
Send a private message to BobPV15
Reply to bob:
Later Bob
You need a manual for the machine. Usually one pump runs a track and the stick, the other a track and the boom & bucket. Some machines have a foot peddle that combines the pumps for the boom lift. So time the extension of each cylinder ( full stroke) and compare to the spec. If they are on spec your pumps are OK and the problem is in the drive circuit. Since you have no issue other than being slow that would point to the rotary valve which has been talked about before. Also if one pump is poor you would notice that in it's digging ability as well.
Fri, Nov 14, 2014 1:54 AM
Wombat
Donor
Reply to BobPV15:
Never had a 235, however did they have a two speed drive? If so maybe one side is in high and the other in low.
Fri, Nov 14, 2014 3:38 AM
bob
Reply to Wombat:
The very last ones used a drive motor similar to that of a 973 and a heavy foot switch to control the speed. Pilot oil was uses to select motor volume.
Later Bob
Fri, Nov 14, 2014 4:07 AM
tacacat
Reply to Wombat:
No 2 speed , wish it was that easy
Thanks Tim
Fri, Nov 14, 2014 6:57 AM
