Excavator issue
Excavator issue
Showing 1 to 9 of 9 results
I have a 1996 320 caterpillar excavator and it all of sudden it does not want to move left and right. It will move forward and backwards. Can someone tell me what possibly is wrong
thanks
Mon, May 20, 2024 6:05 AM
Wombat
Donor
My guess is it has blown the seals in the distributor/pivot in the centre of the circle.
Wombat
Mon, May 20, 2024 8:18 AM
PhilC
Reply to Wombat:
Wombat
I assume by left and right that you mean it will not slew left or right. Not sure about the 1996 320 whether it uses hydraulically piloted valves or electrically piloted but if there are no obvious signs such as blown hoses then perhaps a faulty pilot valve. Could also be in the joystick. If electric check all cables for damage or corrosion. Also if there is a fuse for each function then it may have blown. As both directions are affected it could also be a seized spool for the slew.
There could also be an issue in the slew motor itself. Does the engine sound like it is loading up when you try to slew left or right?
Mon, May 20, 2024 5:49 PM
bluox
Thank you received: 12
[quote="[email protected] post=256889 userid=17728"]I have a 1996 320 caterpillar excavator and it all of sudden it does not want to move left and right. It will move forward and backwards. Can someone tell me what possibly is wrong
thanks
You know a little more detailed description of your problem would possibly  get you an answer to a fix .
Bob
 [/quote]
Tue, May 21, 2024 12:32 AM
Thank you received: 111
Reply to bluox:
thanks
Bob
 [/quote]
Hi, [email protected]
Are you talking about steering the undercarriage or slewing the upper deck on the undercarriage?
Tue, May 21, 2024 5:53 AM
I mean that the machine will move forward and backwards on the tracks but won't move left or right.
Wed, May 22, 2024 5:58 AM
bluox
You mean it won't steer left or right?
What happens when you go forward on one track and reverse on the other>
Bob
Wed, May 22, 2024 6:03 AM
PhilC
Reply to bluox:
Bob
If it won't steer left or right with the tracks it could be something wrong with the brake circuit but seems unlikely to affect both sides.
Perhaps if you posted the serial number I can look up the hydraulic circuit drawing in Cat's SIS.
The more information you can provide us with the more likely we can provide a valid solution.
Wed, May 22, 2024 3:12 PM
Wombat
Donor
I go back to my original post, often the seals in the distributor in the centre of the circle blow and you get oil feed between various drive functions.
Wombat
Thu, May 23, 2024 9:10 AM
bluox
thanks [/quote]
Since it seems to be a secret what lead up to this problem and we don't have a clue how about this WAG are you running the drive motors in low range?
Bob
Thu, May 23, 2024 10:53 AM
