Engine timing on. Thirty
Showing 1 to 6 of 6 results
Sthorpe
Send a private message to Sthorpe
Need help timing the engine on a Thirty. Is the number one cylinder closest to the radiator? Can’t seem to find the timing mark on the flywheel. What doesn’t it look like?
Mon, Jan 10, 2022 2:26 AM
Yes closest to the front, firing order is 1-2-4-3
Mon, Jan 10, 2022 2:34 AM
Sthorpe
Sounds good, Do you know what the timing mark on the fly wheel looks like?
Mon, Jan 10, 2022 7:00 AM
Reply to Sthorpe:
No I don't, sorry. Probably just need to clean the flywheel good.
Mon, Jan 10, 2022 8:47 AM
Sthorpe
Ok,Thanks for the help!
Mon, Jan 10, 2022 9:16 AM
bruce oz
Thank you received: 21
Reply to Sthorpe:
remove number 1 plug to find tdc , i think the flywheel can be put on in any bolt pattern so timing marks may not show up on the flywheel ? at TDC ,
Tue, Jan 11, 2022 3:01 AM
bruce oz
Reply to bruce oz:
https://www.acmoc.org/bb/discussion-d72/28746-caterpillar-thirty#233711
Tue, Jan 11, 2022 3:06 AM
