Engine rebuilding parts
harleybrad
Send a private message to harleybrad
Hi Were can I got rebuilding parts for a old D4 Cat? 7U 48652 I'm thing maybe late 4o's
Rod, main bearing and rings. I wont junk her, maybe shim the bearings, not sure about the rings.
Can anyone help., Thanks
Brad Nadon
logger, road builder
Eureka, Montana
Cat D4 and D7 old guys
Wed, Mar 22, 2017 7:48 AM
Usually this is the best place to start!
http://www.acmoc.org/bb/showthread.php?492-Cat-Parts-Sources-List
Florin is pretty popular for hard to find parts and surprisingly CAT still carries lots of parts for the U series.
Wed, Mar 22, 2017 6:22 PM
Thank you received: 64
Reply to drujinin:
Like Jeff wrote. Cat usually has most of the bearings, seals, and gaskets. Sometimes undersize bearings are not in stock at Cat but searching machinerytrader.com with your part # (there's a Parts Search link on the left side) generally turns up a vendor with them. I usually try Cat first on the basis that if they see the demand, it provides more encouragement to keep stocking them.
If undersize bearings are not available at all, sometimes they can be made e.g. plain bushing-type bearings found in the pony motor main bearings - I've just had some made out of stock, or you can build the journals back up to std (which I've done with my 5U D2 main crank). Lots of options. There are also Cat Classic parts available for some part #s but fitting can sometimes be an issue so I tend not to go in that direction.
Of course used there's a great supply.
Wed, Mar 22, 2017 9:07 PM
harleybrad
OK great news for my old Cats, Will check them out. Thanks
Wed, Mar 22, 2017 10:06 PM
oldbeek
Reply to harleybrad:
Florin was 50% off of Cat price on a pair of thermostats. They were brand new in a military cosmoline box. Nice to save $90.00.
Thu, Mar 23, 2017 10:37 AM
chriscokid
Reply to oldbeek:
i have had very good luck using these guys in Alcoa TN.
https://www.offroadeq.com/
they offer, new, used, and aftermarket on most if not all parts.
Fri, Mar 24, 2017 7:39 PM
