Engine Overhaul
Engine Overhaul
Showing 1 to 10 of 14 results
Macca
Send a private message to Macca
Thought I might post some pics of the 4G engine overhaul. It has been trying to say the least๐Ÿ˜„
Sun, Oct 21, 2007 4:16 PM
Thank you received: 60
Hi Macca,
Looks good to me๐Ÿ˜„ ๐Ÿ˜„........ and I like the precautions you take to keep various openings sealed up. The caps on the injectors pumps are standard 3/8" 37 deg (JIC)(9/16-18 thread) if any one is interested.
Also you can just make out the bellhousing location where the usual direct start would go and see that the raised boss does not exist on the 4G and it will not accommodate the direct start conversions.
Sun, Oct 21, 2007 10:11 PM
Jack
Hi Macca,
Nice to know what the fitting is on the pumps. I might even get some caps for my service work next time. I've been shoving a fuel hose over a pump and clamping it, doing the same with other end of the hose. Like 1 & 3 in one hose and 2 & 4 in another short piece. It works, but not as well. And no class whatever!
Jack
Mon, Oct 22, 2007 8:56 AM
Macca
Reply to Jack:
Jack
Thanks Old Magnet,
may just get to start up the engine next weekend after I make up a bottom radiator pipe๐Ÿ˜Š
Although the hood needs a little modifing from the sheet metal shop๐Ÿ˜
Sun, Nov 4, 2007 5:01 PM
gwhdiesel75
Reply to Macca:
Thanks Old Magnet,
Macca, you've come a long way. Looks good! GWH
Sun, Nov 4, 2007 8:46 PM
R4pat
Send a private message to R4pat
Reply to gwhdiesel75:
Macca, have you started your 4g yet, I have a rd4 4g, doesn't start good, wounders if you did any thing with your injection pumps, if you were able to get any new parts for them, I'm looking for lifters if you know of any
thanks,
your 4g looks great, good luck
Tue, Nov 13, 2007 11:25 AM
Macca
Reply to R4pat:
thanks,
G'day r4pat,
Haven't started the old girl yet, I had to make up a new bottom radiator pipe for it. After I made it and fitted it up, I filled all the oils in the pinion clutch, pilot motor, main engine and injection pump. I started to fill the radiator with water and it started to come out of the top radiator pipe where it joins on top of the water pump and back to the head, so I made up another gasket and refitted, tightened it up and one of the bolt holes that was repaired before that bolt onto the water pump broke again, ๐Ÿ˜  so off it came again and I brazed it up, waited for it to cool and bolted her back up again. Filled with water and now it leaks between the pony adn block.๐Ÿ˜  ๐Ÿ˜  ๐Ÿ˜  aargh I say. I thought that the seal between the pony and block was obselete so I ahd made up my own o-ring, but ckecked and they are still available through cat for $7.00.๐Ÿ˜  ๐Ÿ˜  ๐Ÿ˜  ๐Ÿ˜  so hopefully this weekend she is watertight and I can start her up. I may even try to get a video onto YouTube๐Ÿ˜„
Tue, Nov 13, 2007 3:32 PM
mcclan_9
Send a private message to mcclan_9
Reply to Macca:
G'day r4pat,
Macca,
Good Luck, BTW please take a video of the startup and post it for us. We'd all love it!!!!
D2-4U 2065
Wed, Nov 14, 2007 1:06 AM
Macca
Reply to mcclan_9:
Macca,
here are a couple of pics of my progress, still got a fair bit of the fiddly stuff to do though๐Ÿ™„
[img]http://img60.imageshack.us/img60/1435/p1000354xw9.th.jpg[/img]
[img]http://img140.imageshack.us/img140/5703/p1000356lx4.th.jpg[/img]
Fri, Jan 2, 2009 7:14 PM
TooManyIrons
Send a private message to TooManyIrons
Reply to Macca:
That is a thing of beauty to be sure. Excellent job! Ditto on the video with sound? Did you end up installing new liners and pistons in her?
Sat, Jan 3, 2009 3:10 AM
d23j
Reply to TooManyIrons:
Macca, love the track frame covers!!!!!! P.S Santa dopped a big yellow present at my place for you will ship it up to the hot north soon. regards Andrew
Sat, Jan 3, 2009 5:59 AM
| Kingaroy, Queensland
