Engine Identification and Rating
Showing 1 to 6 of 6 results
pmduke
Send a private message to pmduke
Hello All,Would any of our experienced members be able to confirm the engine in the attached photos is an D8800 and may be able to provide details on the possible horsepower rating and build facility and build date range of these engines.
It came from King Island off Tasmania,
Thank you in advance, Peter
Fri, Sep 11, 2020 1:30 PM
Eds-oldiron
Send a private message to Eds-oldiron
The tag may be off a D8800, but the pictured engine is not a D8800.
Fri, Sep 11, 2020 6:43 PM
Thank you received: 24
Reply to Eds-oldiron:
Looks like a D4600. I don't have the hp rating but I'd guess 70-80. It was used in the D6 tractor, 12 grader (I think), as well as having marine and industrial versions like yours is
Fri, Sep 11, 2020 6:54 PM
bruce oz
Thank you received: 20
hello , i cannot read the tag serial number ,can you post it for me
Sat, Sep 12, 2020 4:39 AM
PhilC
Reply to bruce oz:
I think the serial number plate says 2S702US but is hard to read if there is a number between the S and the 7.
Sat, Sep 12, 2020 7:18 AM
pmduke
Reply to PhilC:
Hello PhilC,
I am advised the serial number plate states 2S5704US.
Thu, Sep 17, 2020 2:45 PM
Reply to pmduke:
Hello PhilC,
Hi,
2S05501-up is a Serial Number range allocated to Miscellaneous Engines.
At a guess these would be engines built to special order and could be any model engine Cat produced at that time.
See scan below from the Cat Product Identification Index, Form No SEBF9451.
I believe that the "US" would signify a US Government contract engine.
I stand to be corrected.
Fri, Sep 18, 2020 7:32 AM
Earlcoate Charity Open Day
