Engine Block Coolent Drain Plug
Send a private message to 196200
Does anyone know the location of the engine block coolant drain plug on an 83J942 D4D? I have found some that could fit the bill but it's not real obvious. Thanks in advance for any help.
Wed, Aug 29, 2007 9:49 PM
SJ
Send a private message to SJ
Check my response on your other posting you put on here below.
Wed, Aug 29, 2007 10:20 PM
Thank you received: 93
Reply to SJ:
Hi 196200,
here is a scan from my 39A-40A-69A OMI, this also has the D330 engine and is from the same era so should be representative of your unit. Would have posted earlier but was out of space and did not want to remove other posts too soon.
Thu, Aug 30, 2007 7:54 AM
