engaging pony motor on D6 9U
D6JP
Send a private message to D6JP
I have a D6 9U. When I pull the starter pinion control lever, it does not engage. Is there an adjustment that can be made? My e-mail is [email protected]
Sat, Jun 1, 2013 2:33 AM
Thank you received: 39
From what you describe the pinion engagement mechanism has probably come apart (typical problem). Will require pulling the pinion engagement assembly to repair, which also requires lifting or removing the pony motor to clear the pony drive gear.
Sat, Jun 1, 2013 10:27 PM
restore49
If a D2 is the same , I had a similar problem where the fingers extended out to far and locked up on the edges - was able to shim to limit movement within tolerance without removing assembly- from memory. Bob
Sat, Jun 1, 2013 11:43 PM
