emission law 2014
emission law 2014
dozerlarry
Send a private message to dozerlarry
What is your take on the diesel engine emission law. I was told that by 2014 all farmer, contractor , loggers will have to buy new equipment ,If the old can not be updated . How will this affect the average cat owner?? I was told that one way to enforce this was that their would be no more new or used parts for older equipment. NATION WIDE is what I was told...
Do you have in info on this stupid law?????
Fri, Nov 2, 2007 12:56 PM
rivercity railroad
Send a private message to rivercity railroad
Party on Wayne, party on Garth????!!!
"They" have alot to do to get to this point! I think we are ok for awhile but just keep a watch out!!!!!!!!!!!!!!!
Cheers- Michael
Fri, Nov 2, 2007 1:10 PM
Art From De Leon
Send a private message to Art From De Leon
Reply to rivercity railroad:
Cheers- Michael
It will be interesting to see how they propose to dry up the used parts supply.
But, it WILL start much sooner if the wrong person gets elected in 2008, and their party retains control of Congress.
Fri, Nov 2, 2007 2:43 PM
SJ
Send a private message to SJ
Reply to Art From De Leon:
Boy some of these nutty people down there have got so technical they are dangerous to us all & want to tear this country apart & it will in time.
Fri, Nov 2, 2007 6:37 PM
Thank you received: 60
Reply to SJ:
The obsolescence plan has already started😠 😠 😠
The latest API Service designation (SM) has cut way back on one of the former lube contents known as ZDDP (zinc dialkyl dithiophosphate) who's sole purpose was/is to provide lubrication for camshafts and lifters as an extreme pressure lubricant in conjunction with molybdenum disulfide. Apparently the ZDDP contaminates catalytic converters and is on the way out. The SM designation has about half the required 1200 parts per million ZDDP required for vintage engines. If you can still get the SG, SH, SL, designated oil your ok but the SM requires additives be added to the oil.
The two suggested in this article are:
Camshaft and lifter prelube GM part #12345501 (4-oz bottle)
Engine oil supplement GM part #1052367 (16-oz bottle)
I'm sure there are others.
Suggested dosage is two ounces per quart of SM-rated oil.
I'd also recommend you take up the discussion with your oil supplier.
Fri, Nov 2, 2007 10:55 PM
2HIGHTEN
Send a private message to 2HIGHTEN
When they put a converter on Nancy pughy"s 747 they can come and talk about what little we are doing. They might also ask her to ride on a reg comercial flight and we will reserve the seat every week right next to the out house door for her and then she can meet lots of common folk every trip to and from work. just my 2cts.
Sat, Nov 3, 2007 9:15 AM
