Electric start to pony
cheshire cat
Send a private message to cheshire cat
Im thinking of converting my DE D2 to pony start , seems it has a different Hood and dash and has a blanking plate over where the pinion would go, is the flywheel different it has a oil clutch if that makes any difference ??
any other things to bare in mind ??? thanks guys
Fri, Apr 1, 2016 1:20 PM
Thank you received: 65
The flywheel is different (5H5090). It has drain holes for the oil clutch. Shouldn't be a problem as it uses the same 93 tooth beveled ring gear as the pony start version.
Fri, Apr 1, 2016 10:18 PM
