Electric Start Pony on D2
Showing 1 to 10 of 10 results
Eric Marshall
Send a private message to Eric Marshall
What size belt (Length/width) is needed feom the starter pinion to the pony flywheel, Instaling a starter on my D2 J, tired of pulling the rope ..LOL
Mon, Apr 2, 2012 10:23 AM
Soapy
Send a private message to Soapy
Wrap a string around the two pulleys, and measure the length. Take it to a genuine parts house, and have a good parts man, if you can locate one, and have him look in the size chart for the correct length. You must also know the width of the "V" in the pulleys, at the widest point.
Mon, Apr 2, 2012 12:33 PM
Thank you received: 78
Reply to Soapy:
Soapy, does one measure the inside or outside diameter of the belt groove? I need to get one for my pony governor.
Neil.
Mon, Apr 2, 2012 11:09 PM
Neil.
If you can post the Cat part number I can probably give you the size.
Mon, Apr 2, 2012 11:27 PM
zootownjeepguy
Neil.
[quote="Neil"]Soapy, does one measure the inside or outside diameter of the belt groove? I need to get one for my pony governor.
Neil.[/quote]
V belts are always measured on the Outside.
Rich Salvaggio
D2 5U9917
Tue, Apr 3, 2012 3:17 AM
zootownjeepguy
I usually wrap a wide tape measure around the outside of the pulleys. That will give you a direct measurement.
To measure a belt, I put the tape in a vise (lightly) and mark the belt with a piece of chalk. Put the end of the tape on the chalk mark and pull out the tape along with the belt and keep going around the belt til you get back to the chalk mark. If you have a helper handy (to hold the tape measure) you don't need the vise. 👍
Rich Salvaggio
D2 5U9917
Tue, Apr 3, 2012 8:17 AM
Eric Marshall
Old Magnet The Cat part number for the starter belt is 6B5653. trying to get all of the parts here before I start to put the starter on the tractor.
Tue, Apr 3, 2012 8:23 AM
josh
Thank you received: 14
Cat #6b5653, crosses to a gates TR22425, several of mine have a 5L 420 belt.
Tue, Apr 3, 2012 8:47 AM
Eric Marshall
Reply to josh:
Thank you Josh that was what I was looking for
Tue, Apr 3, 2012 9:42 AM
Reply to Eric Marshall:
In the 1955 Gates belt catalog 6B5653 is the old Gates number 8520TR for a 42-1/2 in. x 23/32 top width x 44 deg. side belt.
I'd post the pages except it's so darn fuzzy I can hardly read it myself....
Tue, Apr 3, 2012 10:41 AM
STEPHEN
I have bought several from Cat, and they fit perfectly. I don't recall the price, prob to painful to remember!
Tue, Apr 3, 2012 10:50 AM
