electric pony motor starter gear/belt pully bearings....
Hillbillybjopkr
Send a private message to Hillbillybjopkr
so....was wondering if you guys would know how to find the numbers for the bearings in the gear/belt pulley...thingy...that the starter goes into for the pony motor.....started my D4 up this morning and the bearing between the gear and pulley itself....well....hand grenaded in a shower of sparks and metal ....pretty sure I can get the bearing at a local parts house if I had the numbers.....also need numbers for the little bearing on the back side of the gear
Fri, Oct 20, 2017 3:25 AM
gemdozer
Thank you received: 25
The inner bearing 7f8660 and outer 7f8661
Fri, Oct 20, 2017 5:07 AM
Reply to gemdozer:
7F8660 = Bower/BCA 201SS
7F8661 = Bower/BCA WC87504
Fri, Oct 20, 2017 5:15 AM
Hillbillybjopkr
sweet....thanks guys.....picked a set up this morning....parts house happened to have them....now just waitin on wify to get home with the new starter belt....
Sat, Oct 21, 2017 1:58 AM
