Early D6 trans. oil level
Floyd Green
Send a private message to Floyd Green
I have an early D6 CAT tractor 2H7063. I lost my manuals in the Park Fire and I cant remember where the trans. oil level on the dipstick (next to shift lever) should be as there is no mark like on a fuel tank dipstick. Anybody out there know where on the trans. dip stick the oil level should be? Also, anybody know what year manufacture this tractor was?
Thu, May 15, 2025 2:59 AM
Thank you received: 62
No dip stick. A pipe plug on the right side of the case. It has been 30 years since I work on 2H D6. So hopefully not mixing it with another tractor. I believe you can see the plug by removing the seat and looking down on a 2H D6, but I know I can on my AC HD 5. So maybe I am wrong. But I am sure all I have looked at had a pipe plug with square head sticking out so easy to find on the side of the case.
Thu, May 15, 2025 2:40 PM
Floyd Green
I have filled trans to plug on side case but that confused me as nothing shows up on that dip-stick going down from the top. So what is that dip stick for?
Thu, May 15, 2025 3:36 PM
Msjoy
Floyd that worries me. That the oil wasn’t put in the right place
Thu, May 15, 2025 10:58 PM
Where are you finding a dip stick? Is it on plug you remove on top to add oil?
Fri, May 16, 2025 7:18 PM
