Early Caterpillar Power Units and Electric Sets
Showing 1 to 10 of 17 results
CaseyJoeS.
Send a private message to CaseyJoeS.
What sort of power units and especially electric sets did Caterpillar offer prior to the start of the "diesel era" and the products we are all reasonably familiar with? I haven't been able to find much along those lines since that thought popped into my head the other day.
Any information, pictures, literature etc. related to this would be much appreciated
Sat, Apr 12, 2025 3:30 PM
Deebo
Librarian
Thank you received: 74
Interesting question, we’ve a few documents in the members Tech Library with gasoline power units. But I don’t know of a definitive list or chronology of these..
Mon, Apr 14, 2025 7:18 PM
Floyd Green
Send a private message to Floyd Green
I have a couple early (1930s) CAT gas power unit engines out in the field that were originally in John Deere combines (31A I believe). The radiator/fan sits behind the engine with fan shaft running back over the top of the engine. Before the fire I had the original JD 31A manuals that showed the Cat engines but never used the CAT name, only the CAT part numbers.
Sat, Apr 19, 2025 4:32 PM
QuAD
If interested I have about 90 of these old spec sheets for sale
Sat, Apr 19, 2025 4:53 PM
QuAD
Sat, Apr 19, 2025 4:54 PM
D8Dude
Thank you received: 28
Hi QuAD, I'd be interested in spec sheets for the D13000 and D339.
Sat, Apr 19, 2025 9:21 PM
Thank you received: 60
QuAD, that's quite the collection. Would you consider taking a front and back good quality photo of each brochure that we may add to the library, since you have them all in one place at the moment? I'd be willing to make a donation for your time.
Sun, Apr 20, 2025 12:43 PM
1951D2
How much for the D 17000 spec sheets? don't need doubles just single ones.
Sun, Apr 20, 2025 12:45 PM
CaseyJoeS.
I second that it would be great for high quality scans of those spec sheets to make their way into the library.
Is it safe to say that Caterpillar never offered an electric set with a gasoline engine?
Tue, Apr 22, 2025 2:56 AM
josh
Thank you received: 13
Tue, Apr 22, 2025 3:41 AM
Hi Casey, as well as the one that Josh posted (and others you can see in the photos whose model identifiers are appended with a "G"), Cat still makes spark-ignition generators and industrial engines. They usually run on natural gas or landfill gas though. I'm not aware of any that are designed, out of the factory, to run on gasoline although it wouldn't be hard to convert them with a modified ECU and a set of injectors
Tue, Apr 22, 2025 11:40 AM
