dumb question about a d7e
broken1961
Send a private message to broken1961
hi guys,new to this site and really enjoy it,and was listening to a couple guys talking about a d7e, and the cross shaft, which i have no idea what it is, so can anyone tell me what it is, thx
Thu, Feb 16, 2012 11:36 AM
straycat.inc
Send a private message to straycat.inc
It's the shaft in the rear of the machine, that transmits the power from the trans out to the final drives. The final drives are the final gear reduction just before the sprockets (the big gear that drives the tracks).
Thu, Feb 16, 2012 1:19 PM
broken1961
Reply to straycat.inc:
so how do you tell if the cross shaft is out on it?
Thu, Feb 16, 2012 10:58 PM
Reply to broken1961:
Also known as "bevel gear shaft" or "crown gear shaft".
Although on occasion it is possible to break one of these shafts (pretty severe loading) referring to the "cross shaft out" is more commonly in reference to having the cross shaft carrier bearings fail or be out of adjustment. Normally they should be preloaded with no allowable lateral movement which can be checked with prybar through cover plate access at the back of the case.
If they are loose it raises havoc with steering clutch operation, pinion gear to bevel gear mesh/backlash, and can lead to catastrophic failure.
On some tractors, you can actually feel the shaft movement through the steering clutch levers and can also contribute to why you can't get proper adjustment of the release mechanism.
Fri, Feb 17, 2012 2:03 AM
broken1961
thanks for explaning this to me,Scott
Fri, Feb 17, 2012 12:08 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
