Drive links
Drive links
Rep0144
Send a private message to Rep0144
I noticed in another post that some D8's had the clutch main plate fiber links switched to push instead of pull is there any known changes to the D6 since I have the clutch completly apart it would be the time to switch. If was to switch it looks like you would have to turn the main plate around due to the location of the grease zert.
Does make a person wounder if pushing would hold up better seems like less stress on links but maybe they would try to belly out in the middle?
Russell
Sat, Oct 20, 2007 1:27 AM
SJ
Send a private message to SJ
As far as I remember the old dry clutch D6s pulled & not pushed for the ones I worked on years ago.
Sat, Oct 20, 2007 1:37 AM
Reply to SJ:
The reverse links applied to the D8 2U5307 up only using the 9F3358 links.
Sat, Oct 20, 2007 2:57 AM
