Drawn Scraper
Drawn Scraper
Showing 1 to 7 of 7 results
Wombat
Donor
I am looking at a drawn scraper up for auction, photo's only, serial # tag has part rotted away, reads as follows, 2C4018 and the letter F below. Any information about what exactly the model is etc would be appreciated.
Regards, Wombat
Fri, Nov 19, 2021 11:39 AM
Could that be a 21Cxxxx? DW20 and #20  11Cxxxx scraper.
I couldn't find anything with a 2C prefix.
Fri, Nov 19, 2021 12:27 PM
Fat Dan
Could it be a 62C4018 463F 21yd cable scraper?
463F 62C01003 - up
Fri, Nov 19, 2021 12:36 PM
Wombat
Donor
Thanks OM, I have had a closer look at photo with magnifier, it has another number in front of the 2, could be 5 or 6 or 8, the tag is in very poor shape.
Regards, Wombat
Fat Dan
Reply to Wombat:
Regards, Wombat
Caterpillar's Towed Scrapers - Contractor Magazine
Replacing the No.80 in 1955 was the “low-bowl” No.463. This was the most popular of all Caterpillars towed scrapers and was manufactured in several versions over its production life. A variant solely produced in the UK, the 463G, had a modified wider push block for easier push loading by dozer operators. This particular example is a No.463F from 1963.
https://www.pinterest.com/pin/570127634068232252/?d=t&mt=login
 [attachment=65387]scraper.jpg[/attachment]
Fri, Nov 19, 2021 1:01 PM
Wombat
Donor
Reply to Wombat:
Regards, Wombat
Have had a bit more of a dig in a book here, appears it will be a 463, just don't know what year as I have no serial number data for years of production, could be anywhere between '55 and '71, maybe 4018 would be a late one so maybe a 463 F. Should match up with a 270 D8H or D9D OK.
Thanks Fat Dan and OM.
Regards, Wombat.
Fri, Nov 19, 2021 1:02 PM
Fat Dan
Reply to Wombat:
Regards, Wombat.
Best I can come up with is the 463F started production @ 62C01003 in 1960, your 62C04018 is 3,015 from the beginning of the F series and the beginning of the 491B & 491C 24yd scraper 47Exxxx production date (shipping date) started in 1963. I don't know if the 491B replaced the 463F but it seems to be next in the scraper lineup. Hyd or cable ? book don't say.
the picture of the 1963 in my earlier post is the 463F model 62Cxxxx
Fri, Nov 19, 2021 3:34 PM
gauntjoh
Librarian
Reply to Fat Dan:
There are two parts books for 463 scrapers in the Members Technical library.
 [attachment=65391]Screenshot (20).png[/attachment]
Fri, Nov 19, 2021 4:06 PM
