Drawbar Studs and Nuts
Showing 1 to 10 of 16 results
Hank
Send a private message to Hank
I purchased a Drawbar for my 7U D4 and it did not come with any fasteners. I know the nut that holds the Drawbar to the dozer are 3/4" X 16 UNF thread, but I do not know what the stud (Part Number 3B1656) length and thread sizes are. Yes the stud will have 3/4" X 16 UNF threads on at least one end of it, but are the thread on the end of the stud that screws into the transmission housing the same size, or are they different? Also I need to know the length of the stud and if it has any portion of it that is not threaded. Thank you and as always Semper Fi.
HankĀ
Sun, Feb 13, 2022 7:35 AM
rax200
Hi hank,
You are after stud v155 and require 6 of them, you would of found them in your parts book under the transmission case.
Regards
Sun, Feb 13, 2022 9:06 AM
caterpillar13
Reply to rax200:
Hi hank,
Regards
why not just use grade 8 bolts
Sun, Feb 13, 2022 9:48 AM
josh
Thank you received: 14
Reply to caterpillar13:
3B1656 stud, is 3/4" x 3-3/8" NF both ends.
Sun, Feb 13, 2022 10:17 AM
Hank
Reply to josh:
Thank you for your replies and information.
Sun, Feb 13, 2022 12:13 PM
rax200
Hi Hank,here is a screen shot of the cat website showing the size.Ā
Ā [attachment=66818]Screenshot_20220213-181218_Chrome.jpg[/attachment]
regards
Sun, Feb 13, 2022 2:18 PM
Reply to rax200:
regards
0V0155 avail. from Cat, @ $16 each
Sun, Feb 13, 2022 9:16 PM
Thank you received: 54
because bolts may strip or walk out of the housing studs will not. studs make for easier mounting too it much easier to lift a part into position over studs than it is to lift into place and then try and align bolts hence why many things such as clutches have dowel pins. for items like this its important to have the correct grade of fastners or bad things can happen.
either something breaks when it shouldnt or something doesnt break when it should and thus other parts are damaged.costing more time and money.
my grandfather drove a cane harvester for a farmer who was too stingy to remove the stumps from his field and he would plant right upto them so hitting one was a regular occurance,
sick of buying the slightly more expensive sheer bolts for the sheer points in the base cutter and feed screw drives he put normal bolt in instead. guess what the next time it hit a stump instead of a $50 fix and a couple hrs time it cost him hundredsof dollars and several hrs work becuase they had to replace driveshafts and other parts that where damaged and twisted becuase the bolts didnt snap cleanly.
it would have been cheaper to remove the stumps in the first place.
Thu, Feb 17, 2022 12:28 PM
PhilC
Reply to trainzkid88:
Dowel pins are for alignment purposes not for ease of fitting. Unless you have a fitted bolt there will be clearance around most bolts that can cause alignment issues so manufactures fit dowels to reduce misalignment. Other than automotive style clutches I can't think of any situation where the dowels make it easier to fit. Usually they are a tight fit.
I agree though that the original studs should be used rather than bolts as they have the correct thread depth for the application. They can help with fit-up but they can also be damaged when fitting too.
Sun, Feb 20, 2022 4:48 PM
Hank
I was hunting on line for a Drawbar for my D4-7U and found one at Vander Haags. In fact they still have the whole D4 7U Bulldozer they are parting out, or can be purchased as a complete machine (Item 47RE001). The Drawbar was listed for $200.00 and $54.00 shipping from Wanamac, IN. to New Tripoli, PA.. I finally got everything from Vander Haags, the parts came in two different shipments, and I could not be happier with the condition of the Drawbar, Brackets, and Plate. I only got four of the fourteen studs, lock washers, and nuts that attach the Drawbar to the machine. The studs are in good shape, but the lock washers and nuts are well past their service life and I will be replacing them, as I would have anyway. The Stud is 3.25 inches long. The Stud's shaft is 0.750 diameter, with 0.750 X 16 UNF threads on each end of the Stud. There is a .875 inch long area in the middle of the studs shaft that is not threaded. The length of the threads on the end of the Stud that thread into the Brackets and the Transmission Housing is 1.125 inches long, and the length of the threads on the end of the Stud that the Nut and Lock Washer goes on is 1.250 inches long. Knowing what the Stud, Nut, and Lock Washer is going to be used for I would assume that they are at least a Grade 8 quality fasteners. Thanks to the members above there is a Part Number for the Studs, (0V0155). I just thought the information I am posting above could help someone down the road. Thank you and as always Semper Fi.
Sun, Feb 20, 2022 10:51 PM
josh
Reply to Hank:
From what I am seeing, you are looking at two different stud groups, there are the 6, V155 studs that go into the transmission case, for mounting the brackets to the case, they are shown as 3/4" x 2-7'8", one end NF and NC on the other , and 4 of the 3B1656 studs to hold the draw bar to the brackets.
V155 also crosses to L1867 and 5F3855.
Mon, Feb 21, 2022 10:38 AM
