Dozin Down Trees
Dozin Down Trees
Showing 1 to 6 of 6 results
hb11
Send a private message to hb11
I hired a guy to clean up a farm I bought a few years ago and he had some spikes welded on the top of the sides of the blade on his D6 high track. He used these to hit the tree up higher for more leverage to push it over. It worked surprisingly well. I don't know how much stress this put on the upper support arms, but they seemed to hold up.
Anyone ever see a similar pratice?
Wed, Jan 10, 2007 8:10 PM
DaveS
Send a private message to DaveS
I think it was Fleco used to make 'tree dozer' attachments years ago for Cat which pushed the tree higher up than the blade could reach.
Thu, Jan 11, 2007 4:15 AM
RKO
Send a private message to RKO
Reply to DaveS:
[left][/left]Is this what he has welded on his blade? The red painted part on the blade?
I have one on each dozer and even though I do not use a dozer to take out tree anymore, it comes in handy for other things.
Ron[left][/left]
Thu, Jan 11, 2007 8:18 AM
hb11
Reply to RKO:
Ron[left][/left]
The points are about the same as your pictures, but not as thick. He used some 2"x3" flat stock cut to a point.
What did you use yours for? I was thinking about putting some on mine.
Thu, Jan 11, 2007 6:57 PM
SeaBee Mal
Send a private message to SeaBee Mal
Reply to hb11:
Seems like the "Rome Plows" we used in Vietnam to clear trees had a bar above the dozer blade that made contact with the tree before the blade itself made contact with the tree. It helped production particularly in the smaller trees and jungle brush.
SeaBee Mal
Fri, Jan 12, 2007 7:44 AM
RKO
Reply to hb11:
I bought the "CLAW" (that is what it was called) pre made From Nebraska Machinery Used parts about 25 years ago. The Nebraska Machinery new parts never heard or saw anything like it. It is one of the most handy things. I have one on each dozer
Ron
I can get some measurements if you want
Fri, Jan 12, 2007 7:46 AM
AJ.
Send a private message to AJ.
Reply to RKO:
Ron
You may have seen this video before some time back its called The Other Half,its about attachments fitted to Cat machines in the old days,its starts off with the LeTourneau tree dozer,sound on.
Enjoy
AJ
http://media.putfile.com/The-Other-Half-39
Sun, Jan 14, 2007 6:47 AM
