dont know what this is D4 6U
grapegrower
Send a private message to grapegrower
this is attached to the back of the oil pressure gauge one wire from the alternator and the other goes to the amp gauge??
would like to know what this is so I can search for the part.
Patrick
Sat, Mar 21, 2020 5:59 AM
Thank you received: 255
I’m guessing pressure switch. When oil pressure comes up to operating, it kicks off to signal your alternator to go to work.
Sat, Mar 21, 2020 6:08 AM
Thank you received: 46
You can also run a electric hour meter by using the oil pressure switch as power for meter.
Sun, Mar 22, 2020 3:24 AM
