Disconnecting gauges
Showing 1 to 7 of 7 results
BigAgCat
Send a private message to BigAgCat
When you disconnect the oil pressure gauge and fuel pressure gauge, what do you use to cap off the lines to keep oil or fuel from leaking out?
Cat D6 5R
Fri, Apr 3, 2020 10:39 PM
STEPHEN
If you have an extra adapter ell, use it with a pipe cap.
Sat, Apr 4, 2020 5:41 AM
BigAgCat
Reply to STEPHEN:
The problem I have is I have no clue what the size of the connections are.
I looked at the gauges in my parts book and I don't think the gauges match, but the parts book seems to suggest they may be 1/4" or 1/8"
I can probably hit the hardware store if those are the sizes and get some pipe extensions and/or caps. I just do not know what size would be the proper size.
Cat D6 5R
Sat, Apr 4, 2020 5:55 AM
kittyman1
Reply to BigAgCat:
[quote="BigAgCat"]The problem I have is I have no clue what the size of the connections are.
I can probably hit the hardware store if those are the sizes and get some pipe extensions and/or caps. I just do not know what size would be the proper size.[/quote]
-i find 1/8" pipe thread is super common for small lines and fittings...that's where a small box of misc fittings comes in handy...brass, copper, stainless...whatever....and if i don't find something that threads...i just use a plastic cap or plug...and press it on snug...
Sat, Apr 4, 2020 7:36 AM
Reply to kittyman1:
I use electrical tape as it can be stretched tight!
Sat, Apr 4, 2020 8:35 AM
STEPHEN
Reply to drujinin:
Ok, I might have inferred the question incorrectly, I was thinking he wanted to run the engine with the gages removed, so if not, just tape them up. Sometimes I just pull a small square of plastic over the line fitting and all then tape around the knob.
Sat, Apr 4, 2020 10:12 AM
Reply to STEPHEN:
Yea, I see he says leaking out, But he didn't say spraying out! LOL!
Sat, Apr 4, 2020 6:33 PM
BigAgCat
Reply to drujinin:
Haha, yeah. I may try to build a little kit from the hardware store, but could maybe do the electrical tape thing.
Cat D6 5R
Sat, Apr 4, 2020 9:46 PM
| Kingaroy, Queensland
