Difference btwn 941 & 941B
Showing 1 to 6 of 6 results
cptcrnch1
Send a private message to cptcrnch1
Hello!
I have recently purchased a 941 (serial # 80H1666). While tracking down parts, I ran across someone who has a 941B that has blown final drive, but has near new undercarriage and several other parts that I'd be interested in. I'm thinking this 941B might be a good deal for a parts machine, for if/when I need to make repairs on mine.....esp, if I can get it for the right price and get it down to me (its about 2 hrs away). from what I've read, the 941B is just the newer version of the 941....no signifigance differences - dimensions same, engine same, controls etc...but I could certainly be mistaken.
Are the 941B compatible w/ the 941 as far as parts? engine?
is there anything I should be concerned with while using parts btwn these two machines?
I know with a busted final drive, it can be a challenge to get it on/off a trailer. thoughts?
any input anyone has on getting a parts machine, good idea?
estimated cost of a running 941B w/ a blown final drive but near 'new' undercarriage would be worth, would be much appreciated.
thank you! Cheers.
Jr
Mon, Jan 29, 2018 7:59 AM
Jimer
Send a private message to Jimer
I just put sprockets and rails on my 941 reused pads. replaced all bolts and rebuilt a tensionr and one idler. I've got about 3k in parts. if its cheap and you can move it id go for it.
Mon, Jan 29, 2018 10:14 AM
Thank you received: 43
Reply to Jimer:
The 941B uses the 3304 engine , starting with s/n 80H3884. Prior units used the D330c. Far as I know the rest is the same.
Mon, Jan 29, 2018 1:20 PM
catsilver
That's about right OM although I will do quick double check on final drive parts before confirming.
Mon, Jan 29, 2018 3:21 PM
cptcrnch1
Reply to catsilver:
is there a cat resource to confirm what engine I have based on my serial number?
80H1666?
the final drive in this dead unit is dead.
thanks!
Mon, Jan 29, 2018 6:19 PM
cptcrnch1
Reply to cptcrnch1:
80H1666?
thanks!
I believe there's supposed to be an engine data plate on my machine, but I cant seem to locate it in any obvious places.
which is why i'm thinking it best to confirm what I got first. where is plate usually?
my fear is over the years, the engine in my unit has been swapped out.
thanks again.
Cheers
JR
Mon, Jan 29, 2018 6:29 PM
Reply to cptcrnch1:
thanks again.
Cheers
JR
If the water pumps looks like this it's a D330c.
If it's a 3304 the water pump will have a 4-bolt cover.
Tue, Jan 30, 2018 1:47 AM
