diesel thirty five engine questions
EW
Send a private message to EW
Can anyone give me connecting rod clearances and mains. Also would anyone have piston ring part numbers and where to find new ones. Hastings said they don't have them.
Sun, Jun 29, 2014 6:03 AM
Here's the new bearing specs. I don't know of a ring source but I'm sure they are out there.
For 5-1/4 and 5-3/4 bore engines, the wear on the journals should not exceed 0.009" nor should the connecting rod bearing journal be more than 0.007" out of round.
Sun, Jun 29, 2014 6:22 AM
EW
I have taken my engine to a local engine shop and they need spec. sheet for the block, crank, cam, and rods. Would anyone have them or know someone that might.
Thu, Jul 24, 2014 7:35 AM
