Reply to Andrew:
Would anyone have a photo of a machine with the correct air cleaner assembly for Dalby's Forty pilot motor to help him out so he knows what to look for.
Also Dalby after talking to you the other night I seem to remember Bruce Carey from Nobby showing me his RD6 with the same water leak behind the valve springs as you described with yours. I wonder if others have experienced this same problem. Probably a spot on the water jacket where derbis accumulates resulting in a rust pocket. The way most of these machines have been abused over the years it it amazing there is anything left of them.
Andrew .K..
Hey guys
Yeh Andrew i recon your on the money it seems to be leaking around the bottom of the water jacket on the back cylinder over the years built up with mud etc she has got a bit thin in there.
Ive been told that they are the same pilot as the d6 and d7 just with a different timing cover to take the crank handle through the bonnet?
I havent done any research on this myself but gives me a bit of a lead!
Shes very hard to get these bits here in Australia unfortunately.
Thanks for the other info and part numbers guys appreciate it, it will help me try find something.
Steve i would be interested in the forty you know of that might be parting out, if i could just get the air cleaner i could make the rest of the pipe work if i had too
Thanks again
