Diesel Fifty head torque specs?
Showing 1 to 6 of 6 results
Kurt
Send a private message to Kurt
Does anyone know the head torque specs for a Diesel Fifty? Thanks
Sat, Jul 9, 2011 3:01 AM
Thought for sure that someone would come up with the torque specs.....sorry I don't have them either but maybe this will help:
Sun, Jul 10, 2011 7:55 AM
Thank you received: 95
there were never any specs that I have been able to find written in any of my literature. Being that the D8800 (D7) is a bigger bore--5 3/4" version of the D7700 (D50) 5 1/2" this chart for the D8800 should get you there.
Retorque the heads again after the first run and again after some 50 hours of operation as the old copper asbestos gaskets shrink after heating/cooling cycles. That is, the head gaskets will weep.
Sun, Jul 10, 2011 8:24 AM
auscuscus
Send a private message to auscuscus
Reply to edb:
Does anyone know the head torque settings for a D4400. Old Magnet the link you posted no longer works. Not sure what that chart was to.
Regards
Auscuscus
Fri, Sep 9, 2011 9:42 PM
rustrunner
Send a private message to rustrunner
Reply to auscuscus:
Regards
Auscuscus
An old CAT mechanic told me:
1 200# man + 1 2' long wrench + pull as hard as you can = head specs
Has always worked well for me.
Fri, Sep 9, 2011 10:11 PM
Reply to rustrunner:
Probably was this chart........
D4400 head torgue.....
Fri, Sep 9, 2011 10:27 PM
auscuscus
Once again you have helped keep a machine rolling. I thank you.
Interesting they introduced a pre tightening stage when the 315 came in. Different head gasket ? They end up at the same !
Sat, Sep 10, 2011 11:17 AM
