did caterpillar make stationery engines??
Showing 1 to 10 of 22 results
derwen1959
Send a private message to derwen1959
did caterpillar ever make stationery engines and if so what are chances of finding one??
Sun, Jul 22, 2018 8:33 PM
bursitis
yes i believe t hey do and did. i am not sure about their market share though because almost all mfg make them too. in order to find one you would need to find an area where there is demand for them ,like oil field,irrigation,power generation etc.
Sun, Jul 22, 2018 9:00 PM
TimT
Send a private message to TimT
They make all kinds of them,and have for many decades. They also own MAK which builds big marine engines.... If I had to guess market share for standby power or pumping, I would guess Cat is among the largest of them worldwide.
Sun, Jul 22, 2018 9:26 PM
derwen1959
Reply to TimT:
thanks for reply... my original plan was to find a stationary engine version of crawler engine to drive sawbench or as you say across the pond a shingle mill... but I will widen my search for 15 to 20 hp diesel engine which still has V pulleys
Sun, Jul 22, 2018 9:45 PM
Reply to derwen1959:
"yah bet yer boots they did! a whole lotta of em! good luck tryin ta find one though!"
Sun, Jul 22, 2018 10:11 PM
derwen1959
why is that with so many about?
Sun, Jul 22, 2018 10:26 PM
Meant the old ones.
Sun, Jul 22, 2018 10:33 PM
catsilver
Meant the old ones.
Cat are the largest manufacturers of diesel engines in the world, they make thousands of none captive engines for marine power,trucks, generators, water pumps, crushers and many other applications.
Sun, Jul 22, 2018 10:38 PM
derwen1959
Reply to catsilver:
finding a suitable Cat engine with V pulley and not direct drive will not be too difficult with so many variations
Sun, Jul 22, 2018 11:47 PM
"then why ask the question in the first place?"
Mon, Jul 23, 2018 12:30 AM
derwen1959
I did not know that Cat are a large manufacturer of stationary engines until I received replies here..... I am always ready to learn something new.... I am designing a frame to mount the sawbench and engine where the engine will need to move backwards and forward to tension belt and then work out where to put the axle so it is just a bit front heavy
Mon, Jul 23, 2018 1:21 AM
