diagram of D6B idler assembly
Showing 1 to 7 of 7 results
sclan
Send a private message to sclan
Had a seal replaced by a shop and guess what they forgot to put back in?
The slide plates!!😞
They just tightened the bolts down so hard they are stripped. GRRRR
Anyone have a diagram of where the plates go and do you think there is enough room to get them back in there without taking the idler off?
oh boy:behindsofa:
Fri, Jul 27, 2012 11:04 PM
rjh-md
Hate to tell you , but the idler has to come off the frame , You may as well dissassemble both sides and start over .
Fri, Jul 27, 2012 11:39 PM
sclan
Reply to rjh-md:
Anyone want a D6B?
:yield:
Oh Well
Thanks, I need a cold one now. lol
Fri, Jul 27, 2012 11:58 PM
rjh-md
Reply to sclan:
Anyone want a D6B?
:yield:
Oh Well
The flate plates are bolted to each side of the idler shell and have a gasket between the ider shell and plate to seal it .
these are ware plates that are what the bellows seal presses against ,sealing grease in and dirt out . Also retension plates to keep idler shaft in place.
You definitly need them in there!
Sat, Jul 28, 2012 4:33 AM
Thank you received: 50
Reply to rjh-md:
I think reference is to these:
Sat, Jul 28, 2012 5:27 AM
sclan
Yup, those are the plates that are missing.
So, there is no way to get them in there without taking the idler off the frame then?
Not enough clearence I guess,
Mon, Jul 30, 2012 5:58 AM
Thank you received: 33
Reply to sclan:
Hi sclan,
you may get lucky by removing the 4 cheek plate bolts--the 4 bolts tru the side plate and yoke--shown in OM's pic.
You may then be able to lift the yoke high enough to get them in.
If you could get them in as it is now assembled then they would come out in operation, which they can when the idler wears strips wear enough or break off.
Only other problem I see is you need to make sure that the springs and the round discs that sit on top of the springs are in place. If they are you would be OK to go.
If not then the assembly needs to be removed to fit the discs and springs.
Hope this helps.
Mon, Jul 30, 2012 6:55 AM
Reply to edb:
Hi sclan,
Hope this helps.
If you can lift high enough to clear the plates and the spring pilots the assembly is to worn out to use. Idler needs to come off the frame.
Mon, Jul 30, 2012 7:14 AM
