Dent Removal
Dent Removal
Showing 1 to 7 of 7 results
greyhead
Send a private message to greyhead
Hi guys, I have the Hood off my 3T, while it's off. I thought I would work out some dings and dents. Not being a fan of BFHs (but sometimes needed) I was thinking (never safe 😮 ) of tring to shrink them with a torch and a wet rag. But what side of the dent gets the heat, and the wet rag goes on the 😕 other side ??
CAT 977K-11K, JD450-B ,JD690-B, IH TD-9 ,CASE 450-B JD750-E JD850-B
CAT D7-3T, KOMATSU P-68-8 LGP, CLARK 55A LOADER
CLARK MICHAGAN 85-C LOADER, CAT V60 FORKLIFT
And some old AC tractors
Sun, Mar 28, 2010 2:12 AM
Sasquatch
Thank you received: 5
I'm by far no expert on dent removal, but have tried many methods I've found in metal working books. I've never got the heat/wet quench method to work very well, but that's probably because of operator error. The best way I've found to take dents out of thinner sheet metal is to use heat and have a good, flat body hammer and a few dollys of different shapes to provide a good backing to what I'm tapping. You won't get 100% of all dents completely out, and some dents are just too bad to completely be erased.
For round dents I like to take them out working from the edges inward. If they're bumped in pretty good I'll use some heat, concentrated in the middle, just enough to make a red spot in the center. You'll be able to see which way the metal is stressed by whether the dent wants to pull back out or sink further inward. With the worst of the dent heated until red, I start tapping around the edges of the dent on whichever side it wanted to pull towards, with the dolly on the opposite side. I keep the hammer face flat with the surface and direct the blows inward towards the center of the dent, working towards the center. This way with the middle still red it helps to shrink the steel back to flat, because a dent is basically a stretched area. It takes a few dents to learn how much heat to use, because too much can cause ripples and leave it uglier than when you started. Once its cooled I take a file and rasp it over the area I just did, it will show any remaining high spots that need attention. Be patient, let each area cool before doing another.
Long creases are the worst, I can make them better but it's pretty hard to get them all. When I straightened the hood on my 5U D2 it had been beat so badly that the whole thing would spring inward or outward but wouldn't stay flat. I was able to remove the dents and shrink it back to flat using heat and hammers/dollys, it came out real good and doesn't spring any more, but if you look up close you can still see traces of the worst dings it had.
Sun, Mar 28, 2010 3:30 AM
terrywelch_archive
Reply to Sasquatch:
Normally you want to use the heat to shrink the metal that has been streached beyond hammer & dolly work. Toby gave you some good advice. You use the hammer on and hammer off method of working the dent out. The dolly supports the lowest part of the dent and you hammer around the rim to work the metal back in line.
As for a long dent you go from last in to first out. You work the long dent out from the last spot in and it should relieve some of the stress on the crease and help to bring it back in shape.
Years ago when I was learning body repair. one of the things I had to learn is to do metal finishing on a part. Hammer & dolly, pick & file.
None of my hammers are big hammers that I use to straighten sheet metal. They are small and work better than big ones to work the dents out.
Terry
Sun, Mar 28, 2010 7:45 AM
DCurrin
Send a private message to DCurrin
Reply to terrywelch_archive:
Terry
Excellent body work replies.
I think I have learned more from these few paragraphs than all of my books put together.
😊 😊 D2 😊 😊
Stuck Left Clutch, Dang
Sun, Mar 28, 2010 8:21 AM
greyhead
Reply to DCurrin:
Thanks for the info I have had the fun of working with bondo,and didn't want
to go that way . I had seenit done as a kid I thought I might try it, I don't think my wife would like it if i tried my hand on
Her new Van...
Sun, Mar 28, 2010 10:26 PM
D4C Charlie
Send a private message to D4C Charlie
Reply to greyhead:
Her new Van...
In my years as a body man I have found that with large objects like your hood I get good results if I use a steel top table or some smooth concrete to be my dolly. Maybe have someone help to keep the worked areas flat down so you can work them down. I do use a 3# hammer but not slam it just gentley work the dent to the flat surface. The heat comes in when you get things close to straight but the mrtal is stretched. Heat shrinks the excess back into the center of the dent. When you get the oil can effect you are getting close to the right config so try more hot spots to tighten things up. I will also use some sand paper like 80 grit on the back side to see where the highs are then work them down more. Once you get closer then I go to my smaller hammers and dollys to refine things. Hope you get er straightened out some. Charlie
Sun, Mar 28, 2010 11:37 PM
OneWelder
Send a private message to OneWelder
Reply to D4C Charlie:
Cross hatch hammers shrink also slapping files- used with above methods
Mon, Mar 29, 2010 1:12 AM
zootownjeepguy
Reply to OneWelder:
I found by accident a few years back while restoring my 46 Willys Farm Jeep that I could Shrink sheet metal with my MIG Welder. Run a bead down the center of the dent and grind it off flat. It's a bit unorthodox, but it works. I was able to make the flat sides of a Jeep body pretty flat with this technique (and without filler too). It takes a little practice getting the weld bead right. I found that if the weld just barely bubbles the other side of the metal it's where you want to be. I tried the "heat with torch and apply cold wet rag" method and had no luck. It would be best to practice on scrap panels first, and it may not work so well on the thicker gauge metal used on Cat's. I plan on trying this method on my D2 fenders, but right now just getting it to Run is top priority. Good Luck!
Rich Salvaggio
D2 5U9917
Mon, Mar 29, 2010 6:52 AM
| Kingaroy, Queensland
