Delco Mt 42 starter
Delco Mt 42 starter
railroadjoe220
Send a private message to railroadjoe220
I need to replace the bendex on the the starter for my D47j.I need to know how to do it.
Thanks Joe
Sat, Mar 27, 2010 4:41 AM
You need to unbolt the drive end housing (nose) of the starter. It will have hex socket-head bolts countersunk in the face of the flange. Mark it so you can put it back in the same orientation vs the solenoid. Probably will have to also remove the solenoid so you can unhook the linkage and get the drive to slide off the end of the shaft. Should also be a lock on the shaft to remove after you get the nose off before the drive can slide off the shaft.
Do you have the correct drive end housing and starter drive?
Link to OM's conversion pages on ImageShak
http://img400.imageshack.us/gal.php?g=header4oq.jpg
Also see the stick thread at the top of this board for more information about charging, batteries, cables and glow plugs etc.
http://www.acmocbb.org/ACMOC_BB/showthread.php?t=844
Sat, Mar 27, 2010 9:53 AM
Mike Walsh
Delco Remy has a lot of info on their web site also.
http://www.delcoremy.com/Manuals.aspx
Sat, Mar 27, 2010 12:15 PM
| Kingaroy, Queensland
