Deceleration peddle Question
Bumpus
Send a private message to Bumpus
Do they make a deceleration peddle for the old standard shift dozers ?
Or could one be made and work like the newer models have in the floor ?
[B]Meditator:
Opinions Are Like Belly Buttons. We All Have One.
You Got Yours, And I'll Give You Mine. Opinion That Is.
Because I Ain't Gonna Give You My Belly Button.[/B] 👋
Wed, Feb 4, 2015 4:06 AM
D6c10K
Send a private message to D6c10K
Don't know what machine you're thinking of but I found on Cat's online parts site that a D6c 26K tractor is a direct drive / flywheel clutch machine and it shows a decelerator in the parts listing.
Wed, Feb 4, 2015 5:49 AM
Bumpus
Reply to D6c10K:
All of the old standard shift dozers that I have seen only had a throttle leaver on the dash,
but no deceleration peddle on the floor like the newer models have.
[B]Meditator:
Wed, Feb 4, 2015 6:02 AM
The models with the ratcheting mechanism to hold the throttle position made on the governor would be hard to have a decelerator. If the locking/holding part is at the throttle lever, then it wouldn't be too hard to make the change to a decelerator work.
Wed, Feb 4, 2015 6:30 AM
Bruce P
Thank you received: 38
Now that I have a blade on my 17R D6C, I have wondered about putting one on. What all is needed to put one on? The throttle holding mechanism is at the base of the lever on the dash. Maybe get one out of a wrecking yard?
Bruce P
Wed, Feb 4, 2015 7:34 AM
seiscat
Reply to Bruce P:
Bruce P
Hi Bumpus, You did not mention the serial number of the tractor you wanted to put the pedal on. My understanding is that any tractor that was available with a powershift transmission came with a decelerator pedal, and that the decelerator pedal was an option on the direct drive(standard shift) version of the same machine.
This photo shows the factory installed decelerator pedal on my D7E 47A(direct drive) in use. 👍
Wed, Feb 4, 2015 10:06 PM
johan7
Reply to seiscat:
Hi Bumpus , like seiscat stated , the power shift models had decellerator pedals , except the D4D . On this machine it was an option . We had one in the seventies but we installed a decellerator ourselves . the Netherlands , johan7
Wed, Feb 4, 2015 10:30 PM
Bumpus
Reply to johan7:
I have just been thinking that I would like to buy an old Cable Blade D6 with standard shift some day and
I would like to have a deceleration peddle on it like the newer power shift models have.
Just dreaming I guess.
[B]Meditator:
Wed, Feb 4, 2015 10:45 PM
83Jim
Send a private message to 83Jim
Reply to johan7:
When in the market for a dozer, we looked at a D4D powershift with decelerator (two pedals, one near each brake since there are steering levers on the floor). Liked the machine, straight blade with tilt, but we passed on it because no winch and retrofitting one would have required installing a pto disconnect behind the tranny.
The one we bought with 4A manual angle/tilt blade and winch was powershift but no decelerator until we installed one.
You only need two tools in life - WD-40 and Duct tape. If it doesn't move and should, use the WD-40 If it shouldn't move and does, use the duct tape.
Cat D4D 83J w 3304 PC engine, FOPS, s/t blade, D4F winch, air ride seat, "wobble" stick blade lever and D8H control panel
Cat 920 62K w 3304 PC engine, FOPS, 4 in 1 bucket
1995 Dodge Ram 2500 4x4 RCSB Cummins 5 speed
Thu, Feb 5, 2015 3:22 AM
