D9h hydraulic pump question.
Dalton808
Send a private message to Dalton808
Hello everyone,
So we end up buying a d9h that needed work. Had a dead hydraulic system and steering clutch non release issue.
Thay had all sorts of lines hooked up backwards on the pilot system.
The pump however is totaled. It's double gear pump inline. We started looking for pumps and keep coming across vane pumps listed for the machine?
My question is are the gear pumps early pumps replaced by vane pumps? Or vise versa ?
It's the weekend so I haven't spoken to any parts company's yet. It's just been bugging me.
Mon, Aug 28, 2017 6:44 AM
Thank you received: 52
Whats the s/n of the hydraulic control? Tag located top center of the hydraulic control tank.
Mon, Aug 28, 2017 7:37 AM
Dalton808
That's one of the problems were having atm. Trying to get the numbers off the tag. It's really scratched up and weathered. What makes if worse is the serial tags were removed off the tractor.
Would there be any other tags on the hydraulic system?
Thanks in advance.
Mon, Aug 28, 2017 8:55 AM
Reply to Dalton808:
Thanks in advance.
[quote="Dalton808"]That's one of the problems were having atm. Trying to get the numbers off the tag. It's really scratched up and weathered. What makes if worse is the serial tags were removed off the tractor.
Thanks in advance.[/quote]
Only one tag location.
Mon, Aug 28, 2017 11:12 AM
