D9g Transmission flush?
Showing 1 to 10 of 25 results
gvanhouten
Send a private message to gvanhouten
Ok so everything is back together with zero leaks and the engine is staying cool and the transmission is staying cool as well. New coolers should help.
So my problem is as you know the torque/transmission cooler flooded do to it having a leak so water filled the transmission. I drained all old oil out of Torque converter transmission. A lot of water came out and I left it open for 2 days. So I added new to-4 cat transmission oil and now it looks like it has water that is in it... I. WeÂ’d to dump and flush it any recommendations??? I worked it today for 3 hours.
Any recommendations would be helpful thanks
One last thing the oil was 50 weight that I put in from caterpillar that is what they recommended
Fri, Jun 26, 2020 12:59 PM
Use 30W trans/drive train oil, 50 is to slick for steering clutches, actually I would get that 50W out of there asap. Get it up operating temp and drain and change filters.
Fri, Jun 26, 2020 9:11 PM
I don't see any problem using the higher viscosity (SAE 50 TDTO TO-4 spec) oil in your climate.
Fri, Jun 26, 2020 10:41 PM
gvanhouten
Ok Rome I am headed to the store to pick up some 30W trans/drive train oil.... I will use that as a flush as well unless the color pigment stays the way it should... I will also drain the torque converter as well.... I will take out the metal filters and clean them... They are brand new... I will keep you posted...Go figure Caterpillar parts guy said that is what you should run in your machine because the 50 weight because its better for your machine... I do not believe the transmission liked it.....
Fri, Jun 26, 2020 10:49 PM
gvanhouten
Hi Old Magnet, you would drain and refill? I think at this point it is a good idea to drain what is in there and refill with SAE 30/or 50. TDTO TO-4 spec). My only issue is I can't afford to purchase 1100 worth of oil to drain and refill. I should have put some cheap stuff in ran it and dumped that.... I think for peace of mine I will put the cheap stuff in run it for a little and then dump and put fresh in of the proper spec ect....
Fri, Jun 26, 2020 10:55 PM
Reply to gvanhouten:
I just wasn't sure if the 50W you got was spec'ed for use in steering clutch compartments, if so run it for awhile. Dont forget the drain plug on the oil cooler also. One is for coolant and one for oil.
Fri, Jun 26, 2020 11:15 PM
gvanhouten
Hi Rome, it was from Caterpillar TDTO- 50W TO-4 spec.... That stuff is expensive... $133.00 per 5 gallon.... My parts book say it should take 31 gallons of fluid is that with the Torque converter? When I drain I always drain both the Torque Converter and the transmission.
Fri, Jun 26, 2020 11:26 PM
gvanhouten
The good news is the old girl can certainly move some dirt and in addition now with the new coolers she is staying nice and cool... I can work her all day... Yesterday I got some seat time of 3-4 hours.. I took down some huge trees and back bladed and tracked a bit... I was watching some old videos and I am trying not to use my brakes and use the decelerator to control movement...
Fri, Jun 26, 2020 11:31 PM
Good, yes use the engine rpm according to power needed to operate smoothly and full rpm when under heavy load. "Smooth and steady gets it done"
Sat, Jun 27, 2020 2:05 AM
Thank you received: 95
Hi George,
to drain the actual Torque Con. Rotating Housing that is within the main T/C outer housing that is drained by its big lower drain plug, you will need remove the T/C scavenge pump, inside there you will find a ring of bolts that retain the big alloy T/C Impeller to the steel T/C rotating housing.
Only Two of the bolt holes are drilled right thru to the inside of the oil compartment of the housing.
Around the side of the steel rotating housing should be 2 markings, opposite each other, with DRAIN stamped into the rotating housing steel case--the 2 opposite bolts that align to the stamped DRAIN need to be removed to drain some 4-5 gallons of oil from the actual T/C Rotating Housing.
Early units had an Allen head plug or two in the side of the case but these were nasty to try and remove.
If you did not drain the T/C rotating housing previously then this is a likely source of most of the current discolouration you have as it now seems not all of the system's contaminated oil was drained previously.
You will need to de-compress the engine and turn it so as to locate and remove the two Drain bolts, set one bolt hole at around the six o'clock position to drain the case--Refit BOTH bolts after draining.
There is no need to refill the T/C as when you start up again it will refill itself safely.
BUT, be sure to put around 2 gallons of oil into the main outer T/C housing for the Scavenge Pump to pump until the T/C housing refills and starts to leak the required oil to keep the Scav. Pump lubricated so as it does not seize up.
Sat, Jun 27, 2020 8:45 AM
gvanhouten
Reply to edb:
Hi George,
[quote="edb"]Hi George,
If you did not drain the T/C case previously then this is a likely source of most of the current discolouration you have as it now seems not all of the system's contaminated oil was drained previously.
Eddie B.[/quote]
Hi Eddie,
Thank you for the above info... I ran it again today for 40 minutes got it warm and dumped the torque converter and the transmission plug... I estimate at least 33-34 gallons came out and it was nasty looked like baileys Irish cream... I can't believe that it was brand new to-4 50 weight and within 4 hours it looks that bad... Didn't want to chance anything and am dumping it and putting fresh in and if that is bad will dump it again until oil looks good....
Dozer is working wonderfully and I am not using my brakes and got the hang of slowing down with the decelerator and switching the power shift...
My steering clutches work but probably need adjusting... I am not sure but when I go left I pull the steering clutch lever and it needs the brake to really make it move in that direction. I want to only slightly correct steering when in gear either 1st or 2nd.. It seems that the right moves better and reverse moves the best...Not sure if the clutches need to be replaced as the age but she definitely can be steered but am getting to begin to get the hang of it... Any suggestions would be helpful and any real videos to show how to not stress the machine... I fix her so I want to be good to her...Cheers...
Sat, Jun 27, 2020 1:04 PM
