D9G shift stuck
D9G shift stuck
Showing 1 to 9 of 9 results
greengiant
Send a private message to greengiant
I let my hydraulic fluid run low. filled the tank, but it won't shift forward or backward, the lever won't go into either position.. all the other hydraulics work and i worked them hoping to get the air out of the system. is there a bleeder for the shifter?? or what am i overlooking?
thanks!
Tue, Aug 6, 2024 9:34 AM
Wombat
Donor
Blade and Ripper hydraulic system is separate from the transmission hydraulic system, reading your very confusing post I have to assume the tractor is power shift and when you pull the transmission control lever into a forward or reverse gear it springs back to neutral. If that is the case, there is no oil pressure, I would check the oil level in the transmission case first, if it is full to level mark, then lift floor plate and see if the jack shaft is spinning. There is a bleed on top of the transmission pump, I would be very reluctant to suggest removing it, if it gets oil pressure it will squirt out under great pressure, most mechanics remove plug with engine stopped and screw in a brass tap and elbow directing oil away from danger.
Wombat
Tue, Aug 6, 2024 4:18 PM
greengiant
Reply to Wombat:
Wombat
thanks for the info that the systems are separate. i assumed they were from the same reservoir as the blade and ripper started showing lack of fluid at the same time the shift lock occurred. i filled the reservoir and the blade and ripper smoothed out but the shift lever will not pull into forward or reverse at all.just moves back and forth in neutral.
The transmission oil is full.
I know what you mean about the pressure plug modification. My D7E has it.
Tue, Aug 6, 2024 10:11 PM
Thank you received: 76
Reply to greengiant:
What does the service reference say about priming the transmission? I'd think that it might have some information in the scenario where the transmission was drained for maintenance/repair and the valves, etc. drained.
Tue, Aug 6, 2024 10:34 PM
bluox
Check the safety neutral bar on the shift tower.
Bob
Tue, Aug 6, 2024 10:35 PM
greengiant
Reply to bluox:
Bob
it's good, no problem with it.
Tue, Aug 6, 2024 10:39 PM
seiscat
You can find answers to your D9G transmission questions in the ACMOC library. Look for the testing and adjusting powershift transmissions manual.
Craig
 [attachment=77300]IMG_20231109_0001.jpg[/attachment]
Tue, Aug 6, 2024 10:40 PM
greengiant
thanks!
Tue, Aug 6, 2024 10:45 PM
sven leupi
Send a private message to sven leupi
Reply to seiscat:
Craig
Hello
I got a simular issue, but somtimes it goes ito gear, it moves for a few seconds then the clutshes start slipping after that it throws it in neutral, that menas no transmissionfluid pressure, but i can drive forward with no issues, only in reverse it loses pressure
Do you have an idea what it could be?
Or can you send me that servicemanual for the transmission? Because i cant open the one you already sent
-sven
Fri, May 16, 2025 12:06 PM
Thank you received: 62
Reply to sven leupi:
Hello
-sven
The library is for paid members. If you are new member it has been taking a long time, so ask for help of the moderator. Good luck.
Fri, May 16, 2025 3:13 PM
