D9G ser#66a3445
D9G ser#66a3445
Showing 1 to 9 of 9 results
durtrivertruckingcompany
Send a private message to durtrivertruckingcompany
Hey folks. I'm looking at a D9G with a pan pusher blade on it. My concern is while working on soft ground I won't be able to raise the blade up high enough for the machine to back out if she starts to sink.
Would anyone be able to pull the part numbers off of they're c frame-material blade/cylinders and brackets so I can see what I can dig up online?  My other concern is it's the old style single cylinder in the front. I can plumb hydraulics but are there any structural differences as far as when I go to drill and tap cylinder brackets?
I'm not to keen on having to buy an entire parts machine just to make something work so I much rather find what I need used.
Thanks in advance.
Thu, Aug 22, 2024 7:01 AM
bruce oz
Thank you received: 23
9C Bulldozer Attachment ,
https://www.jensales.com/categories/caterpillar/9c.html
Thu, Aug 22, 2024 7:16 AM
Reply to bruce oz:
I don't see the g series listed on this book.
Thu, Aug 22, 2024 7:34 AM
bruce oz
Reply to durtrivertruckingcompany:
D9 66a3445 BUILT 1965 ? , The 2 serial number for 9C cushion blade ,70F start 1960 , 45G start 1971 , ,, 70F would be closet to your tractor ?
Caterpillar 9C Bulldozer Attachment Parts Manual (S/N 70F1+) (jensales.com)
Thu, Aug 22, 2024 8:01 AM
Thank you received: 140
Hi, durtrivertruckingcompany. (Heck, I got writer's cramp just from typing that name.)
There will very likely be mounting facilities on each side of the hard nose to carry the beam with the ram mountings that goes with the angle and straight blades. This is a round beam that mounts on both sides of the back edge of the hard nose and contains the swivels for the ram mountings in each end.
This arrangement was also used on many of the cushion push blades.
I don't have the extensive libraries of parts books, etc., that some other member have and so I can't post a scan of the parts page.
Hope this helps.
Thu, Aug 22, 2024 8:07 AM
Reply to bruce oz:
I'm sorry sir. I'm afraid I don't understand what you're telling me.
Thu, Aug 22, 2024 8:19 AM
Hope this helps.
Thank you sir!
Thu, Aug 22, 2024 8:20 AM
Thank you sir!
Hi, durtrivertruckingcompany (more typist's cramp.)
Maybe a video will help:
https://www.youtube.com/shorts/xVEzI0vPq8g
https://www.youtube.com/watch?v=o-zjDLKmHQw
Thu, Aug 22, 2024 8:38 AM
There is nothing comparable between the 9C cushion blade and regular straight or angle blade arrangements.
Look into Parts Manual Form  #UE070070
Thu, Aug 22, 2024 10:14 AM
Thank you Mr magnet.
Thu, Aug 22, 2024 10:22 AM
