Reply to edb:
Hi murfman,
the best I can do is this scabby old photocopy of a chart scanned below.
The chart only works if you know the nut Part No from a Parts Book.
If you can give me the model number of your hydralic control I can likely get specs for ripper cylinder nut torque as the Cat Spec sheets I have go by HCU Model number for the cyl. nut specs.
Those 191/2/3 controls I have checked seem to be 860-1060 lbft for the ripper cyl. nut.
Hope this helps.
I have come up with some info out of the D9H books......
9D ripper
s/n's 97L-up,22M1-up,39M1-up and 40M1-up
6J7810 ripper tip cyl group ( 8.25" bore X 20.70" stroke )
Rod diameter 3.498"
Nut torque - 3000ft lb (+/- 300ftlb)
4J6888 nut.......... Takes 4" socket
7X2725 repair kit
7J1487 ripper lift group ( 9.20" bore X 21.0" stroke )
Rod Diameter 3.248"
Nut torque - 3000ft lb (+/- 300ft lb )
4J6888 nut...... Takes 4" socket
146 9624 repair kit
I would imagine yours would be the same if you have quad rippers.
Cheers djcat
